LinkBack | Thread Tools |
so i was getting ready to change my fork oil. i let out the air and drained the oil. then .. neither top plug would come off. i tried wd40, a wrench, vice grips, tapping it, loosening the triple tree .. nothing worked. i beginning to believe i'll need to get new forks but maybe there's some trick they didn't explain in the service manual.
thanks for the help, .d.h. |
Uncle Bob's Love Child
similar to a KZ1000. I use a socket with a half inch breaker bar to break the caps loose. It will take a bit of effort, they stick. If you want an interesting experience, pull the drain screw out before bleeding off the air pressure.........used fork oil does not come out of clothes.......chris3
Forgot to add: your fork cap may be held by the upper triple tree bolt so loosen it first......chris3 Last edited by coppertales : 05-23-2007 at 12:01 PM. Reason: add info |
bustedfeet
Remove the forks from the bike, then apply some heat with a propane torch.
Mine were stuck - wouldn't budge. After applying the heat, they came right out with a crescent wrench. It's helpful to remount them in the triple tree. I have a spare triple tree, so I do mine on a work bench with the forks sticking up a few inches out of the upper triple so that I can clamp the uppers & lowers. JMK. |
| Plug misfiring at top speed | Metal_God50 | The Mechanics Corner | 5 | 09-29-2006 08:04 PM |
| 80 KZ750 sprocket cover removal, etc. | Sparkadelic | The Mechanics Corner | 1 | 06-02-2006 11:09 PM |
| Fork Removal on Mean Streak | Abegian | The Mechanics Corner | 1 | 09-19-2005 08:01 PM |
| oil drain plug removal direction zx6r | davidlust | Main Lobby | 7 | 05-08-2005 04:34 PM |
| 82 KZ750 Spectre Top End Engine Rattle | Luxury | Vintage Motorcyle Info | 2 | 05-19-2004 03:23 PM |
