Old 11-01-2004   #1 (permalink)
Jesus Rivera
Send a message via Yahoo to Jesus Rivera
Default 1997 Vulcan classic 1500 Shifting problem
I just bought a Vulcan 1500, I was told about a shifting problem ( it grinds when shift from 1st to 2nd ), I took apart the engine, checked the gears , drum, etc. The only thing I found was the Return Spring bolt bended.
I replace the bolt, put everything back, and adjusted the shift linkage rod.
But still doing it, when I shift from 1st to 2nd it will grind, if I shift at 17 miles like Kawa. specified it will not grind but it is not enough speed for the 2nd gear, the higher shifting speed the worst it gets, to the point that it will jump to neutral.
If anybody has any info. please let me know.
Thanks.
Jesus Rivera is offline   Reply With Quote
Old 05-20-2008   #2 (permalink)
Zeddisded
A member of the Wub Club!
Zeddisded's Avatar
I have the same bike same problem!!!!!!!!!
Always someone trying to ice skate uphill!
Zeddisded is offline   Reply With Quote
Old 05-20-2008   #3 (permalink)
SureClassic
"Rode hard put away wet"
SureClassic's Avatar
same here....... doesnt jump out of gear.. but grinds like heck at higher speeds..
97 1500 Classic (Black is beautiful)
SureClassic is offline   Reply With Quote
Old 05-20-2008   #4 (permalink)
flareside
I have the same problem. Change the oil and see if that helps. I can get it to stop shifting, or grinding if I shift it slow into second gear.
Hope this helps
flareside is offline   Reply With Quote
Old 05-20-2008   #5 (permalink)
SureClassic
Hope this helps
Same,,,,, short shift it and it all well..... as long as I am not hauling a trailer with a big load.. sometime you need more revs...........
