Old 06-11-2007   #1 (permalink)
hayward6
Former Marine
hayward6's Avatar
Default 84 ZN1100 carb question
Well this weekend I pulled the carb assembly off and cleaned the carbs out, of course I forgot to remove the stupid jet that sits under the washer (I allways forget that step) and I'll need to do it again, but it is running better. My question is about something I found while I was in there. between the 1-2 and 3-4 carbs there is a solid plastic line going between them they each come out to a plastic tube that looks as if there should be a hose on it or capped. The only thing that looks close on the diagram is what they call the air vent and it looks like there were some hoses on it in the original diagram... anyone know what thats for and if it will help me at all to try and run it like its meant to be? the hoses are deffinetly long gone.
1984 ZN1100 LTD -SOLD-
1975 Suzuki T500 Titan -Project-
hayward6 is offline   Reply With Quote
Old 06-11-2007   #2 (permalink)
hayward6
Former Marine
hayward6's Avatar
one more thing... the stock air box ****ed me off to no end when it came to putting everything back together. Is there a cheap alternative to using the box? (not the K&N's that cost more than my bike) I know it could throw off my air flow, but wow I never want to work with that air box again.
Old 06-11-2007   #3 (permalink)
Bucko
2004 Vulcan 1500 Classic
First of all, if thats all the paitants you have about the air box my suggestion is to get rid of the bike now and save your sanity. If you want to tix it we can do that also. There are work arounds for everything but some take patiants. All hoses on the carburater are important and must be in place for the bike to run right. First of all lets go back to the carburater. What jets are under a washer? If your talking about the float, ok, I know where youare at. Starting at that piont, remove the float by sliding the pin that it hinges on. You may have to use a small pin punch but be careful. Under the float is a screw thast holds the float jet in place, remove it and pull out the jet and seat. If it pulls out easy the you are going to have to replace the O ring on the seat. this replacement part is , I will have to get it later but you can buy them at Lowes or any place that sells o Rings for about .10 cents each. I will also get you the info on the hose hook up.
Bucko is offline   Reply With Quote
Old 06-12-2007   #4 (permalink)
elr658
Eddie Lawson is God!
elr658's Avatar
Do you need me to come up there and make it run?
1982 Kawasaki KZ1000R1 #658
1983 Honda CB1100F Blue.
www.myspace.com/79cb750f
Old 06-12-2007   #5 (permalink)
hayward6
Former Marine
hayward6's Avatar
No the needle jet is what im talking about, I'll be taking the carbs off again on Friday and I'll take a picture of the fitings im talking about that seem to be missing hoses. The bike isnt running "bad" just not right. I drive it to work everyday.
Old 06-12-2007   #6 (permalink)
hayward6
Former Marine
hayward6's Avatar
hmmm, expert consultation? how much is that going to cost me?
Old 06-12-2007   #7 (permalink)
A2rider
Banned
If he shows up, we want pics. And it wouldn't matter what it cost, having a vintage mechanic show up to help with my bike would be the highlight of my year!
A2rider is offline   Reply With Quote
Old 06-12-2007   #8 (permalink)
hayward6
Former Marine
hayward6's Avatar
No kidding! I'm just not sure if he was being serious or sarcastic yet
Old 06-12-2007   #9 (permalink)
elr658
elr658's Avatar
Serious, I actually LIKE those bikes.
Old 06-12-2007   #10 (permalink)
hayward6
Former Marine
hayward6's Avatar
I'd love to let you have a look at my bike, maybe a test ride would help you see what the trouble is I hope to put alot of time in on it this weekend, carbs, valves(if I can get a valve cover gasket) and everything else I can check.
Old 06-12-2007   #11 (permalink)
A2rider
Banned
Careful there, my friend, you are showing your soft side
And Really, I want pics of the great and mighty ELR. Mechanics are hot!
Old 06-12-2007   #12 (permalink)
hayward6
Former Marine
hayward6's Avatar
If I can talk him into making the trip up here I'll be sure to take pictures... if he says its ok
Old 06-12-2007   #13 (permalink)
elr658
elr658's Avatar
Don't go crazy adjusting the valves, as I HAVE THE FACTORY TOOL!!!!
Old 06-12-2007   #14 (permalink)
A2rider
Banned
Don't ask! Just take the pic, run like he!! and hide the camera!
Old 06-12-2007   #15 (permalink)
hayward6
Former Marine
hayward6's Avatar
I doubt Ill have the gasket for this weekend anyways, but im pretty sure most of my trouble will be in the carbs.
Old 06-12-2007   #16 (permalink)
elr658
elr658's Avatar
Then outrun the flying wrench.
I am on the Honda CB750/900/1100F SuperSport Website thread concerning the northeast ride. I am standing next to a 1979 CB750F Bagger. Not mine. In my HD shirt.
Old 06-12-2007   #17 (permalink)
A2rider
Banned
Alright, I'm blond, but I don't see a body in that picture. You're a really good mechanic, but your not invisible!
Alright, I think I found you!
Old 06-12-2007   #18 (permalink)
elr658
elr658's Avatar
I'm on the tshirt too.
Old 06-13-2007   #19 (permalink)
Bucko
The hoses you are talking about are vacum lines. One goes to the fuel valve and one goes to the vacum switch valve which is probably missing. Cap them off and you will notice a big difference. It should also smooth out the engine.
Old 06-13-2007   #20 (permalink)
hayward6
Former Marine
hayward6's Avatar
Are you sure? I dont see anything about that in the book... heres a picture, the hose is the black think between the carbs, sorry its so blurry. Both of these we're disconnected from any tubing.
GPX750R - carb question? qzak Vintage Motorcyle Info 10 04-09-2008 05:43 AM
ex500 carb question MN250R Kawasaki Streetbikes/Sportbikes 4 10-17-2006 12:38 AM
'89 Ninja 750 Carb Question Glaxtx Kawasaki Streetbikes/Sportbikes 3 06-29-2006 03:16 PM
Newbie question re 2004 Classic Carb versus 03/05 Classic FI scharfg Kawasaki Cruisers 14 11-22-2004 10:15 PM
90 EX500 carb question 71_307 The Mechanics Corner 1 09-15-2004 02:00 PM
