Old 11-12-2004   #1 (permalink)
tissan
Default Hey guys a couple of questions about 89 600R *pics added*
Well first off, what do you think would be a good price for a complete 89 600R roller (minus engine + plastics)?
Also, when my 600R motor was shipped to me it fell forward on the pallet and put a little crack in the valve cover (think epoxy/or JB-weld would fix this little crack?)
And also when it fell forward it cracked one of the cam holders (one of the 6 that have a threaded hole to bolt the valve cover to) any idea where i can get another one? i checked the Kawasaki Parts Fiche and couldnt find it
and this one i just found cracked stupid DHL
Anyhow, i just CANT find a part number.
and what is a good oil to run in the 600r?
TIA guys!
tissan is offline   Reply With Quote
Old 11-12-2004   #2 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
Default Re: Hey guys a couple of questions about 89 600R *pics added
Originally Posted by tissan
Well first off, what do you think would be a good price for a complete 89 600R roller (minus engine + plastics)? not a whole lot maybe 500$
Also, when my 600R motor was shipped to me it fell forward on the pallet and put a little crack in the valve cover (think epoxy/or JB-weld would fix this little crack?) -clean it with ether and put a nice thin coat of JB-WELD on it. let it dry for DAYS. preperation is the key.
And also when it fell forward it cracked one of the cam holders (one of the 6 that have a threaded hole to bolt the valve cover to) any idea where i can get another one? i checked the Kawasaki Parts Fiche and couldnt find it and this one i just found cracked -ya didnt look hard enough cause they should have it. also might want to check with www.ronayers.com www.bikebandit.com and your local dealer
and what is a good oil to run in the 600r? -i run YAMALUBE in my bikes along with a STOCK filter (no aftermarket filters no much how cheaper)
TIA guys!
QKENUF4U is offline   Reply With Quote
Old 11-18-2004   #3 (permalink)
tissan
thanks alot QKENUF4U, i accutally ended up paying 185 shipped for the whole roller
Other then missing most the bolts and the gas tank is dented its not to bad.
TA
