Old 09-14-2007   #1 (permalink)
Alizard
The Cruising Gunsmith
Default What Holds the Valve Stem Oil Seal?
I am getting parts to do a valve job on a 1979 KZ 750. The Kawi service manual says to install the oil seal onto the valve stem and then put the "clip" on the seal.
The diagram has an arrow pointing to the center of the seal saying there's a clip there, but it doesn't show the clip as a separate piece.
Is there a metal ring clip to hold the seal to the valve guide?
What does hold the seal in place?
Thanks
Alizard is offline   Reply With Quote
Old 09-14-2007   #2 (permalink)
elr658
Motorcycling's Dr. House
elr658's Avatar
The seal is speared to the valve stem with a spring squeezing the stem. The VALVE GUIDE is retained by a spring clip. The seal is retained to the guide by a lip of rubber in the seal. You will need NASTY pliers.
1982 Kawasaki KZ1000R1 #658
1980 Kawasaki KZ750H1 LTD
www.myspace.com/79cb750f
Old 09-17-2007   #3 (permalink)
Alizard
Is that spring clip supplied with the new seal?
The Kawi service manual says there is a clip, but the explosion diagram does not show one, not does it list it as a part. So, I have no way to order the clip.
Old 09-17-2007   #4 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
Comes with the seals.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 09-17-2007   #5 (permalink)
Alizard
very good, thanks.
Weird Idle after oil change, engine dies, low power delivery (1993 EX500) Popsmear The Mechanics Corner 2 08-14-2007 12:27 PM
[txt] Changing oil - men vs. women anamosity Off Topic 17 04-12-2006 11:48 AM
oil seal problem miczehr Kawasaki Motocross and Offroad 5 03-15-2006 07:57 AM
What Oil To Use (?) My research! Brewmaster Kawasaki Cruisers 29 03-11-2006 07:45 PM
How to change oil on 99 ninja 500R mixery2k The Mechanics Corner 8 01-22-2004 07:49 PM
