Sit speling cheker
I was cleaning my bike and thought I would remove the saddle, what a mess. There was sand and road grime everywhere! After cleaning it all I noticed that the inner fender and the main fender had a large gap, what a design flaw?
I took the tool tray off to clean it and this exposed the battery. It too was covered in road grime. I thought I would remove the battery, I peeled back the red rubber and this is when I noticed that the positive post was covered in battery acid corrosion. Anyone out there know why the positive post would do that? Thanks
Candy Fire Red, Vulcan 900 Classic CMC # 43022 Senior Rd.Captain,6th Officer SCRC # 399084 VNOG # 030 |
Gear Head
It's actually common with any automotive battery. If you want to stop it, here's what I'd do.
First, scrub the terminal and clamp with a battery brush, then go to Autozone, and get some felt washers and terminal grease. (The washers will only work if you have a round terminal) The washer will absorb and neutralize the acid, and the grease will keep corrosion down a LOT.
92 Sedan DeVille Sold 99 Crown Victoria K&N Drop-In Filter, ECU Retune, more to come Yea, I'm THAT hardcore |
#3 (permalink) | |
Sit speling cheker
What causes it? Do I need to replace the battery? Thanks
#4 (permalink) |
Banned
OK, I was bored, but here is some answers.
Battery Maintenance is an important issue. The battery should be cleaned using a baking soda and water mix; a couple of table spoons to a pint of water. Cable connection needs to be clean and tightened. Many battery problems are caused by dirty and loose connections. A serviceable battery needs to have the fluid level checked. Use only mineral free water. Distilled water is best. Don't overfill battery cells especially in warmer weather. The natural fluid expansion in hot weather will push excess electrolytes from the battery. To prevent corrosion of cables on top post batteries use a small bead of silicon sealer at the base of the post and place a felt battery washer over it. Coat the washer with high temperature grease or petroleum jelly (Vaseline), then place cable on the post and tighten. Coat the exposed cable end with the grease. Most folks don't know that just the gases from the battery condensing on metal parts cause most corrosion. |
#7 (permalink) |
If you clean the terminals with a baking soda paste made from water and baking soda the coat the terminals and wire lugs with vasaline or just grease your problem will go away. The corrosion needs oxygen for the reaction.
John 2002 Mean Streak |
#10 (permalink) |
Sit speling cheker
Okay, all said and done,............I'm alarmed!
I have never had this sort of thing happen to a battery before. I buy a car every 10 years and never had this happen. I have owned several motorcycles and never came across this. So, why now?
#13 (permalink) |
really needs his bike D:
![]() Join Date: Apr 2006
I'd have to say, I haven't been around as long as some of you but I've been playing with motorized... things for over a decade and I haven't come across this problem either. Wasn't even sure what he was talking about at first.
1995 Candy Red Ninja 500 *R.I.P.*1997 Peacock (LOL!) Blue Vulcan 500 |
| 1981 ltd 550.. battery acid... | austin_0_4 | Kawasaki Streetbikes/Sportbikes | 1 | 06-04-2007 10:57 PM |
| VN900LT Electrical Problems or just bad battery? | Roscoe75 | Kawasaki Cruisers | 17 | 05-12-2007 11:03 PM |
| battery acid | zedx11 | What I learned today | 41 | 04-09-2006 03:30 PM |
| Battery Problems | r409z | Kawasaki Streetbikes/Sportbikes | 4 | 11-12-2005 01:54 AM |
| Battery replaced, now no power... Please help | tedsim | Kawasaki Cruisers | 12 | 04-13-2005 02:54 PM |
