Old 12-18-2007   #1 (permalink)
jeffbort
Default 86 kx125 top end ?
does anyone know the correct way to install the two barrel like water port controllers on this top end? there is a teethed rod that controls where and when the water enters the top end and where the water goes. on the one cover on the top end it says kips the rod connectes to the lower end near the water impeller. a diagram would help if anyone has one. the barrels are also diffrent im not sure which one goes where
jeffbort is offline   Reply With Quote
Old 12-18-2007   #2 (permalink)
YurFatMom
Jedi master
YurFatMom's Avatar
That is not a water control device. It is a power valve. Search on the internet for Kawasaki OEM parts, and you should be able to find a parts fiche.
'03 YZ250
'03 Kodiak 400
'05 YFZ450
I turned blue!
YurFatMom is offline   Reply With Quote
Old 12-19-2007   #3 (permalink)
jeffbort
yeah they are the power valves. i found a diagram on kawasaki.com but its just a parts diagram. i cant find anything elses that explains how to postiton theses p/v
Old 12-19-2007   #4 (permalink)
YurFatMom
Jedi master
YurFatMom's Avatar
When you put them in, they should be closed.
'03 YZ250
'03 Kodiak 400
'05 YFZ450
I turned blue!
Old 12-19-2007   #5 (permalink)
jeffbort
yeah but should the rod be all the way to the left looking at the exhaust port or the right. and also one has 2 holes and the other one half of the barrel is open i dont know what one goes where and what ports they are closing and oopening. there are 2 ports on one side of the cylinder and 4 ports on the other side. this is a tough one
Old 12-19-2007   #6 (permalink)
YurFatMom
Jedi master
YurFatMom's Avatar
Post this in the Motocross and Offroad thread, or PM FPMXer. His bike has the same powervalve design and he just got done rebuilding it, so he should be able to walk you through it.
'03 YZ250
'03 Kodiak 400
'05 YFZ450
I turned blue!
Old 08-30-2008   #7 (permalink)
Phatlipcustoms
Phatlipcustoms's Avatar
Any luck on that ? I have the same problem
THanks
Phatlipcustoms is offline   Reply With Quote
1st top end installation kx5and8 Kawasaki Motocross and Offroad 4 08-13-2007 02:50 PM
Rod inspection while replacing top end? beebe Kawasaki Motocross and Offroad 8 10-24-2006 12:17 AM
86 kx250 top end kyle1! Kawasaki Motocross and Offroad 3 04-17-2006 12:08 PM
Top End help gixxer_76 Kawasaki Motocross and Offroad 1 04-04-2006 01:11 PM
1988 kx125 top end? jim fin Kawasaki Motocross and Offroad 2 10-18-2005 01:54 AM
