What does this hose hook up to on 250 ninja carb
+ Reply to Thread
Results 1 to 5 of 5
Thread: What does this hose hook up to on 250 ninja carb
  1. #1
    Join Date
    Oct 2004
    Posts
    5
    Default What does this hose hook up to on 250 ninja carb
    I recently got a 98 250 Ninja that has been sitting for two years and a hose is missing from the T that goes between the tops of the two carbs. I dont know what this hose is for or if it needs to be hooked up to something, they look like they might be a vent for if the float valve stays open but I would inmagine that 92059C needs to get hooked up to something because it could let dirt right into the float bowls........ any insight would be appreciated.
    I have put a picture of the pieces in question at
    http://www.joeschorsch.com/ninja.htm
    JCS
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    AZ's Official Mechanic BTK Expert QKENUF4U's Avatar
    Join Date
    Sep 2004
    Location
    COTTONWOOD ARIZONA ! JUST DOWN THE HILL FROM 158 corners in 12 miles...
    Posts
    5,029
    its just a vent line. put a new hose on it that hangs down between the carbs.
  4. #3
    Join Date
    Dec 2004
    Location
    Hawaii
    Posts
    8
    Hey Ive got a similar question:
    I took apart my carb and cleaned it, and now I cant figure out how to properly hook the thing back up.
    I know where the main fuel line goes, but the other line coming from the tank is giving me a problem.... I dont know where to plug it in, nor do I know where to plug in the two-to-one coming out if the top of the throttle bodies in the carb......
    Please help!!!!!
  5. #4
    Join Date
    Sep 2004
    Location
    Posts
    5,029
    Thumbs up
    Quote Originally Posted by routine8
    1. the other line coming from the tank is giving me a problem.... I dont know where to plug it in,
    2. where to plug in the two-to-one coming out if the top of the throttle bodies in the carb......
    1. is this a smaller line that comes from the petcok ? if so then that is your vacumn line and it goes to your #1 carb nipple between the carb body and the head.
    2. the two-to-one line is just a set of vent lines. just leave it alone or put a longer line on it and run it down towards the rear wheel area
  6. #5
    Still On The Kickstand BTK Beginner sci fly's Avatar
    Join Date
    Jan 2005
    Location
    Geriatrics state
    Posts
    42
    www.ninjaguide.com for the people with ninjas, they have all part specs and engine specs since about 89 for most models
    '05 ex500
    mIRC
    efnet
    #mcchris
    TheDogsB
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
