Old 04-29-2008   #21 (permalink)
Roofgunner
Turtle Wax Taster
I only serviced one police bike that the Vallejo, CA. PD had. I remember the city mechanics thought they could do some work on it but screwed it up and after that I took care of it. So, it's hard to know what kind of maint. your bike has had. I sold my 900 and I don't have the book on it anymore, so I'm assuming your valves are adjusted. I'd pull the head off and have a look see in there. It will never start, much less run with the comp. you have. I only ever had one bad head gasket on a 900 or 1000 that came from the factory. Who knows, maybe someone had it apart and didn't assemble it right.. If needed pull the jugs off and examine the pistons. If you want to pull the valves apart and you don't want to purchase the Kaw valve spring compressor, you can make one using PVC pipe and a big c-clamp. JB weld the PVC pipe (cut to fit and use a dremel to cut out the slots so you can pull the valve retaining pieces out. If you need help email me.) I'd tell you to question your compression tester, but since it won't start at all, the readings you get are probably accurate. There might be a possibility that the cam timing is off but you probably should have noticed this when you checked the valves as the timing/cam marks would be off. But, my guess since none of the pistons have proper compression some body ran it with out oil and all the pistons are screwd up or scored. If you are lucky, it's just the headgasket. Just take the thing apart.
Roofgunner is offline   Reply With Quote
Old 04-29-2008   #22 (permalink)
Bicycle Lee
Thanks, gunner. I'm going to continue taking the top end apart. The valve cover gasket got damaged when I removed it so I'm gonna get a new set of gaskets anyway. I figured that's the cheapest place to start. I'm not rich by any means so I'm doing this piece meal. I appreciate your insight and I will be letting you know what I find along the way.
Bicycle Lee is offline   Reply With Quote
Old 05-02-2008   #23 (permalink)
KZBob
New Guy
KZBob's Avatar
If you don't keep on the valves you get this......
93000 miles on the 1982 KZ1000 ....and I just plain neglected it....
KZBob is offline   Reply With Quote
Old 05-23-2008   #24 (permalink)
Mercury
Mercury's Avatar
Send a message via AIM to Mercury
welp, I got 18500 miles on myu 800 drifter, I figure ill check the valves next tire change, (about 28000 miles)
im sort of scared to do it, these engines seem impossible to really work on (chassis center in way and such)
my ATV was no prize either to work on, but i adjusted those valves cause I did not care much if i screwed it up
kenny
2000 drifter 800 - lightly modded
2003 360 4x4 atv
Mercury is offline   Reply With Quote
Old 06-02-2008   #25 (permalink)
Turbofeber
Finally Got Into First Gear
Turbofeber's Avatar
my engine ticks like its threatening to spit the valves out - but i'm genuinly scared to open up the engine ... scared i wont get it to run after
1981 Kawasaki KZ650SR
Turbofeber is offline   Reply With Quote
Old 06-22-2008   #26 (permalink)
stevekx
If I were to use Seafoam, Kreen, GM Top Engine Cleaner or even just Chevron Techron to de-carbon my valves, where and how do I pour in the bottle?
stevekx is offline   Reply With Quote
Old 06-23-2008   #27 (permalink)
P049417
Paul
Looking for a little advise, after reading these threads regarding valve clearance.
#1) How or why might I have 2 valves (out of 4) one intake, one exhaust, slightly out of tolerance on the high side? My only guess is previous adjustment brought it out w/ new shim. I just bought it, 2006 KX 450F.
#2) How much is too much? My exhaust is out on the high side by 0.03mm, spec is 0.17mm-0.22mm, actual is 0.25. Intake is out by less, 0.01mm or so. This seems very minimal to pull cams and measure shims and reorder shims, etc, etc. And these are out on the high side?
Thanks,
P049417 is offline   Reply With Quote
Old 06-26-2008   #28 (permalink)
Robert1320
Old Skool rider
Robert1320's Avatar
Thanks for the info guys.
I'll be looking at my Concours this weekend!
CDR Performance
317-445-3719-Robert
Machine & Speed Shop-Domestic V-8 Turbo and ProCharged motors
Robert1320 is offline   Reply With Quote
Old 06-29-2008   #29 (permalink)
snardle
Bob
snardle's Avatar
Roofgunner: would the encreased clearance also hold true for KZ44oLTD? If so how much more of a clearance?
snardle is offline   Reply With Quote
Old 06-29-2008   #30 (permalink)
snardle
Bob
snardle's Avatar
Hey guys what i s sea foam? and where do u get it?
Old 07-08-2008   #31 (permalink)
rockhound1371
rockhound1371's Avatar
Send a message via Yahoo to rockhound1371
why do good books always have cliff hanger endings...
rockhound1371 is offline   Reply With Quote
Old 07-08-2008   #32 (permalink)
bamavulcandave
Pass the taters!
bamavulcandave's Avatar
Seafoam is in most auto parts stores, wal-marts here.
Good to run every so often to help keep carbon build-up.
bamavulcandave is offline   Reply With Quote
Old 07-09-2008   #33 (permalink)
Mercury
Mercury's Avatar
dont u mean to help kill carbon build up
kenny
2003 360 4x4 atv
Old 07-09-2008   #34 (permalink)
bamavulcandave
Pass the taters!
LOL! Yeap, my bad, thanks Kenny.
Old 07-12-2008   #35 (permalink)
Jeff.saunders
Obsessed by Z1's
Jeff.saunders's Avatar
Send a message via AIM to Jeff.saunders
Just to amplify ELR's information.
We get so many calls of people wrestling with bikes running rough. Many times these owners are attacking the carbs or ignition without even looking at the valve clearances.
If you buy an older motorcycle, other than changing oil and filter, the first thing you should do is check the valve clearance. On some bikes like KZ550-KZ750 fours the clearnaces are often neglected as the adjustment shims are UNDER the valve bucket - this means the cams have to be removed to make valve lash changes...
As ELR said - there's not too many situations where valve clearance increase (although a few bikes like bevel Ducati's do see this).
Here's my quick list of things to do on a bike that's just been acquired.
1) change oil & filter
2) check valve clearance
3) check ignition timing (regap points & lube mechanical advancers)
4) replace any inline fuel filters
5) check spark plugs - regap or replace - make sure heat range is correct
6) sync carbs
If you do use Seafoam or Yamaha's Ringfree in the fuel, recheck the valve clearances after you've run a tank full through the bike. The carbon removed off valves and seats can cause the clearances to change a fair amount.
jeff@z1enterprises.com 1973 turbo'd Z1, 1973 stock Z1
www.z1enterprises.com
Jeff.saunders is offline   Reply With Quote
Old 08-04-2008   #36 (permalink)
Sid Throttle
Thumbs up Kawasaki Newbie Seeks Advice (Valves).
Hi folks, I'm a newbie to the site from the UK and a newbie in the land of Kawasaki Heavy Industries! I hope I can contribute to the site in the future and would be grateful if I could draw on your massive collective motorcycling knowledge!
I've got hold of a cheap ZX7R (20,000 miles on clock) and am a bit concerned as bike has not been cared for - I've got bills for the first crucial services but nothing for valve clearance checks - I took the head off last night and measured the clearances - three valves appear out of clearance - the valve that is most out of clearance is out by 0.04mm (intake valve measuring 0.13mm - tolerance range is 0.17mm - 0.25mm). Don't know if a valve this out of clearance has done damage or not? - I guess I'll have to do a compression test after reshimming to check for valve sealing issues?
Thanks in advance for any advice. Kind regards, Sid.
Sid Throttle is offline   Reply With Quote
Old 08-17-2008   #37 (permalink)
elr658
Motorcycling's Dr. House
elr658's Avatar
Sid, I don't think you did any damage, BUT you should (Or probably DID) set that right.
1982 Kawasaki KZ1000R1 #658
1980 Kawasaki KZ750H1 LTD
www.myspace.com/79cb750f
Old 09-15-2008   #38 (permalink)
dannyb83
Default valve clearance
hi all
could somebody please tell me
what the valve clearances should be
on the zxr400 l8 model please many thanks daniel
dannyb83 is offline   Reply With Quote
Old 09-28-2008   #39 (permalink)
coolbrezz860
Ole650 rider
coolbrezz860's Avatar
Ive been reading your info on valve and the 650 is more complex to do as it requires removing the cams as the shims are under bucket, make sure you have a book handy to reinstall the cams properly. Also i worked for Yosh years ago and we found that if you go to the high side of the clearance it actually increased Compression from what i was told at the time it changes the valve overlap and or cam timing but that was years ago but again i saw it with my own eyes and it always worked Just my 2 cents
coolbrezz860 is offline   Reply With Quote
Old 09-28-2008   #40 (permalink)
Saleenguy
Dazed and Confused
Saleenguy's Avatar
Often the caps can be removed and the cam just tipped....or just one removed, and one loosened a lot, and then tip the cam.
use a magnet to remove and replace the shims, less likely to drop them.
Plug any holes with a rag(s) to stop parts falling down them.
I have had a few bikes hauled to me over the years in pieces when a guy doing his valves at home dropped something inside the motor....could be a nut, shim, or whatever.
I like making crap when its slow, or i need a stress break...so built a spring compressor that works on some bikes ( not all by any means) and then if i need to just change say 1 shim, can do it without popping the cams loose.
Riding is good for ones soul.
Riding amongst friends is even better.
Saleenguy is offline   Reply With Quote
Noisy ZX7 engine... valves? Fixion The Mechanics Corner 7 10-02-2008 12:51 AM
Why you should not neglect your valves. elr658 Projects and "How To" Write Ups 26 01-31-2008 07:42 PM
