Old 02-06-2008   #1 (permalink)
climb_eng
Default 1995 EN500 Cylinder Gasket - Replace?
Last night I was pulling the cylinder head off of my 1995 Vulcan 500 (I've got coolant in my oil!). As I was hammering on the head to break the gasket, the cylinder gasket separated (the one that connects the cylinder to the crankcase).
I have the head off now, i'm wondering if it's a good idea to replace my cylinder gasket as well, or should I just replace the head gasket, tighten everything back together and proceed as normal.
Also, my coolant looked very clean, it's just the oil is all chocolate-malty and foamy, plus I'm losing coolant as I ride. What other paths are there for coolant to get into the oil besides the cylinder head gasket?
climb_eng is offline   Reply With Quote
Old 02-06-2008   #2 (permalink)
elr658
Eddie Lawson is God!
elr658's Avatar
Mechanical seal on the water pump which is MUCH more likely than a head gasket.
1982 Kawasaki KZ1000R1 #658
1983 Honda CB1100F Blue.
www.myspace.com/79cb750f
Old 02-07-2008   #3 (permalink)
JimmyD
really needs his bike D:
JimmyD's Avatar
+1 on the water pump. It is pretty rare for the head gasket to go in these engines.
Be careful when removing the water pump cover, IIRC you have to remove a bolt from the impeller first and remove it. If you pull the whole thing you will break off the impeller.
I've never pulled the head on my bikes but I have read from those who have that this engine likes to leak after reassembling. New gaskets and a lapping/resurfacing to be safe.
1995 Candy Red Ninja 500
*R.I.P.*1997 Peacock (LOL!) Blue Vulcan 500
JimmyD is offline   Reply With Quote
Old 02-07-2008   #4 (permalink)
JimmyD
JimmyD's Avatar
After looking at the parts diagram I'd have to say that the screw comes out of the impeller, and then the impeller unscrews as well. I also think it's reverse threaded, lefty tighty, righty loosey.
Don't quote me on that though, its been a while.
1995 Kawasaki EN500 jerrjazz@verizo Want to show off your ride? 7 4 Weeks Ago 03:14 AM
cylinder gasket codie97 Vintage Motorcyle Info 0 07-02-2006 06:52 PM
No Cylinder Head Gasket! ckevg Kawasaki Motocross and Offroad 10 05-14-2006 05:17 PM
Anyone with a 1995 Vulcan EN500? Can you help me out? MusicMaverick Kawasaki Cruisers 0 06-09-2004 05:50 PM
