Can't find time to ride
i put on my new short stalk signals about an hour ago and all but 1 work fine. the left front stays on constant and wont flash so the rear left blinks rapidly. i have double checked all my wiring and cant find a solution. any ideas?
2005 zx-6r "the only replacement for displacement is technology" |
Sit speling cheker
Did you get the dual filament for the front? Three wire? If you only have the single filament, two wire, you have the running light hooked up, but not the blinker. When one blinker blinks real fast, it normally means the bulb on the other is out.
I say anything new is good by definition. It can shock, insult or offend me. So long as it doesn’t bore me! 04 Ninja 500 My Web Page |
#4 (permalink) |
i disconnected the running light wire and now the turn signal works but i have only 1 running light lol.
#5 (permalink) |
Sit speling cheker
Did you try switching the Turn and running light wires? They may have wired it wrong.
#7 (permalink) |
wow, something so small and stupid as the running light and turn signal leads being wired backwards from the factory can cause hours of confusion and anger.
thx for suggesting that diver, that was the problem. man just changing the lights changes the whole appearence of the bike. time for a short ride before work
#8 (permalink) |
Sit speling cheker
Glad it worked! Post a pic, I've wanted to change my lights out, but have not found anything I like yet. Also, are they as bright as the stock ones?
Later
