Chain Rattle
+ Reply to Thread
Results 1 to 9 of 9
Thread: Chain Rattle
  1. #1
    Formerly Phaedrus BTK Beginner Principal's Avatar
    Join Date
    Apr 2008
    Location
    Southern Utah
    Posts
    101
    Default Chain Rattle
    Just adjusted the chain on my 81 KZ550 LTD. Was at about 1 and a half inches play, took it down to about 1 inch. Made sure the notches on the adjusters were in the same spot on the swingarm marks. Now the chain 'rattles' as it travels. Didn't do this before. It sounds very rough at times, and occurs regardless of speed (I can even get it to do it just turning the wheel on the centerstand.) I have lubed the chain, and tested the wear at the back sprocket, and it seems ok. Any suggestions?
    What is good, and what is not good...need we ask anyone to tell us these things?-R. Pirsig
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Navy Vet Search & Rescue BTK Expert StarGate's Avatar
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,894
    Off hand I'd say it's one or more of the following. Too tight, sprockets worn and need replaced, rollers worn and chain needs replaced.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  4. #3
    Join Date
    Apr 2008
    Location
    Southern Utah
    Posts
    101
    SUre appreciate the help StarGate. I'll look into these things.
  5. #4
    Member BTK Expert
    Join Date
    Mar 2006
    Location
    KCK
    Posts
    19,728
    +1 on Stargate's advice.
  6. #5
    Join Date
    Apr 2008
    Location
    Southern Utah
    Posts
    101
    Loosened the chain a bit, much better. Still some rattle when backing up, is this normal?
  7. #6
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,894
    That sounds like a worn sprocket and chain not meshing together well because of stretch and worn/hooked teeth. And no thats not normal.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  8. #7
    Join Date
    Apr 2008
    Location
    Southern Utah
    Posts
    101
    OK, new sprockets and chain coming up. THanks again. Stargate going to owe you a steak dinner for all the instruction.
  9. #8
    Join Date
    Apr 2008
    Posts
    36
    When there is weight on your bike the chain tension is tighter than when the bike is on its center stand. I learned from an old flat track Harley racer turned KAW dealer who suggested running the chain as loose as possible just so it doesn't hit anything. I immediately made that adjustment on my 1980 550 LTD and later my 1984 GPz 1100. I also lube the chain at the end of a riding day only. I was initially concerned about the loose chain but after experiencing much longer chain life with no mechanical problems even at 140+ mph I stick by Stan's advice.
  10. #9
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,894
    Quote Originally Posted by D.O.C. View Post
    That depends on how much the rider weighs and how much preload is set on the shock springs. It can vary for every bike and rider combo.
    If you ever had a chain jump off the sprocket and lock up the rear wheel you might change your mind on that point. Been there done that, but luckily it was at about 30 mph and I was able to keep the rubber side down until it stopped.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. manufacturers suggested!!!
    By daemon in forum What I learned today
    Last Post: 05-12-2008, 08:24 PM
  2. Chain Slack Measurement
    By Simon in forum The Mechanics Corner
    Last Post: 05-19-2007, 09:56 PM
  3. the chain thread
    By zedx11 in forum The Mechanics Corner
    Last Post: 05-11-2007, 09:23 PM
  4. Chain noise (it is hitting the frame) vulcan 800A
    By su1kil in forum The Mechanics Corner
    Last Post: 12-20-2006, 08:37 AM
  5. Cam chain rattle?
    By greenmonster in forum The Mechanics Corner
    Last Post: 04-09-2004, 11:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
