KZ550 Starter Clutch?
+ Reply to Thread
Results 1 to 20 of 20
Thread: KZ550 Starter Clutch?
  1. #1
    Join Date
    Feb 2008
    Posts
    34
    Default KZ550 Starter Clutch?
    I have a 1981 KZ550-C that I have starter issues with and was wondering if someone could help me. The starter will not turn the bike over at all. All I get is a grinding or loose noise from inside. I figured that that the clutch was bad and bought a used one off E-bay. Started taking mine apart yesterday and found that the teeth on the used clutch gear and my starter don't match. Let me stop here and say I bought the bike used with the starter issue and was told that they had replaced the starter to try to fix it themselves. Then I look up inside the engine and the large gear in there dosen't look the same as the used one I have and doesn't appear to be the same tooth pattern as the starter. I can stick a screw driver inside and turn the clutch to the front but not to the rear so I don't think it's the clutch causing the problem. Can anyone shed any light on this problem?
    Lynn
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Navy Vet Search & Rescue BTK Expert StarGate's Avatar
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,893
    OK, you are trying to match the teeth of 2 different items that never come in contact with each other. The starter needs to match the teeth of the idle gear (picture #2). The clutch needs to match a different set of teeth on that idle gear but they are not visible for you to check. They are smaller in diameter and on the opposite side from the camera in picture #2. Look at the parts breakdown on kawasaki.com and you might get an idea what I'm talking about.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  4. #3
    Join Date
    Feb 2008
    Posts
    34
    Thanks, I didn't realize there was a gear between the two, guess I should have done a little more research before my posting.
    Thanks,
    Lynn
  5. #4
    Join Date
    Feb 2008
    Posts
    34
    Got the bike apart and back together with any gliches and did it through the oil pan. Thanks for your help and advice! If anyone needs a Step by Step of the process complete with pictures let me know I will be glad to send them to you.
  6. #5
    Newbie big dee's Avatar
    Join Date
    Nov 2008
    Location
    sunny florida
    Posts
    21
    just sent you a message about your step by step changeout, thanks Dennis
  7. #6
    Join Date
    Nov 2008
    Location
    sunny florida
    Posts
    21
    thanks Lynn ...........you da man, at least I know what im going to be involved in, as i recall 15 years ago this bike made strage noises when it cranked over, kinda like it was kicking out and grinding..........
  8. #7
    Visionary
    Join Date
    Jan 2010
    Location
    Disneyland
    Posts
    6
    Unhappy Grinding when trying to start!
    I'm having a similar probley.
    Now since I traded my RC car for this Kz550 1981, I've had to go threw some minor problems, but after going over this bike the main issue is starting. The problem is when try to start/sometimes I get a loud grinding noise. Sometimes I can get the bike to crank over, but other times it just sounds like the thing is a grind core band on JoLT!
    I just took off the starter shield on the left hand side, and I came to discover that maybe it was that clutch thing that may have been to loose, in other words, maybe the clutch was not being engaged properly???. I took off the starter, and it seemed fine, even thought it was of a replacement. I also connected the starter to the battery and it turned over/it was not a dead starter. When this bike runs, it is actually a smooth running bike. I wonder if it even has all that many miles on it really. I can sometimes try to start this thing with out it turning over, and all's I get is this loud grinding sound??? Anyone have a clue?
  9. #8
    Join Date
    Feb 2008
    Posts
    34
    Send me your email and I'l get some helpful information off to you.
    Lynn
  10. #9
    Join Date
    Nov 2008
    Location
    sunny florida
    Posts
    21
    Default kz550 starter clutch
    I remember you sending me this info when I had the same issue, I PM 'ed him to send info along also.....................you da man , if he needs it you can send it if not I think I still have it......................it was spot on, just finished my resto but have not added fuel yet...........................but the starter works great
  11. #10
    Visionary
    Join Date
    Jan 2010
    Location
    Disneyland
    Posts
    6
    Default Starter clutch...
    Quote Originally Posted by lhemrick View Post
    I need into on the starter clutch, such as diagrams, or pictures. My Kz550 81' is making a grinding sound and does not start. Also this time around when I would attempt to jump start it like I had in the past, the rear wheel locks up, and it would not achieve the push start. I was thinking maybe it was the clutch not working as to why it's not starting, but Kawa Dealer say's maybe it's the Starter Clutch *($70). I had also mistakenly replaced the starter itself which made no difference. All teeth appear to be fine both on the starter, and the gear it comes in contact with.
  12. #11
    Join Date
    Feb 2008
    Posts
    34
    Send me your email address and I'll get it sent to you.
    Lynn
  13. #12
    Join Date
    Nov 2008
    Location
    sunny florida
    Posts
    21
    just sent you an e mail LYNN
  14. #13
    Join Date
    Nov 2008
    Location
    sunny florida
    Posts
    21
    just sent you an e mail Lynn
  15. #14
    Join Date
    Apr 2010
    Posts
    1
    Default Re: KZ550 Starter Clutch?
    One of you want to email that stuff to me. i just got a kz550ltd and its going to have the same problem... i just know it..lol
  16. #15
    Join Date
    Oct 2011
    Posts
    1
    i would be eternally greatfull if soemone could email me the hints and tips for this starter clutch malarkey to jridley3@googlemail.com
    cheers in advance
    Jim
  17. #16
    Join Date
    Oct 2011
    Location
    fort smith arkansas
    Posts
    1
    i would really like to have this information as well mine is doing the same thing ! mattsmith72933@gmail.com
  18. #17
    Join Date
    Apr 2012
    Posts
    1
    I know this is an old thread but mine is doing the same thing. It's a 1982 kz550. I would love this information. Gas is to expensive to keep driving my truck. I want my bike back. Thank you
  19. #18
    Join Date
    Feb 2008
    Posts
    34
    Hey thenewb, Send me your email and I'll be glad to send them to you.
  20. #19
    Join Date
    Oct 2012
    Posts
    5
    Lhemrick, can you email me the Step by Step of the process complete with pictures, I have a 1981 LTD 750 that I need to do and need help!!! Thanks! My email is onsitepcrepair@aol.com thanks a million!
  21. #20
    Ridin' Red Rock Country BTK Expert sim37's Avatar
    Join Date
    Sep 2011
    Location
    St. George, UT
    Posts
    299
    Lol. I hate to do this, but this is my next project coming up. Starter clutch roller and spring replacement. I think I have a pretty good idea of what I'm doing from my manual but every little bit helps. If somebody wants to send me the information my email is d3e7lewis@gmail.com
    82 KZ1100 D1 Spectre
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. kz 400 starter on a kz 440?
    By Alibi in forum Vintage Motorcyle Info
    Last Post: 09-30-2008, 08:27 AM
  2. Starter clutch 1980 ltd 250 / kz250
    By idrive55 in forum The Mechanics Corner
    Last Post: 11-27-2007, 06:38 AM
  3. Starter?
    By Kawa 1982 in forum Vintage Motorcyle Info
    Last Post: 08-29-2007, 09:12 PM
  4. Bayou Starter Clutch Problems: whining
    By buildcrew in forum Kawasaki ATV and Mule
    Last Post: 04-23-2007, 06:58 PM
  5. starter clutch?
    By 88ex500_inbosto in forum The Mechanics Corner
    Last Post: 06-26-2006, 09:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
