Replacement bulbs for OEM Lightbar?
+ Reply to Thread
Results 1 to 2 of 2
Thread: Replacement bulbs for OEM Lightbar?
  1. #1
    Into the Wind Forum Supporter barry5k's Avatar
    Join Date
    Apr 2008
    Location
    Elk Grove, CA
    Posts
    676
    Default Replacement bulbs for OEM Lightbar?
    I just installed a lightbar for my Vulcan 1500 Classic and I notice that the lights aren't as bright as my aftermarket white headlight. Should I switch them out, but to what? Gadget's site says not to put 55w bulbs in. Would new bulbs make a difference, or are you satisfied with the brightness of our lightbar
    Thanks for your advice!
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Honest it wern't me !! ULTIMATE Forum Supporter GREENISBEST's Avatar
    Join Date
    Nov 2006
    Location
    Northants UK
    Posts
    2,432
    Hopefully someone who has a light bar will respond or you may get better results in the Cruiser section.
    As for the tech side of your Q.
    Check the rating of the installed bulbs you'll probably find there only about 5 or 10w which would be the reason there saying not to upgrade to 55's the circuit will have been designed for the lower rated bulbs so 2x55's will pull to much current.
    Having said that it's not hard to uprate the wiring and fuse but there may be an issue with the light housing not be able to stand the extra heat generated by the 55's.
    END OF KEV's MESSAGE !
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Lightbar bulb replacement
    By Kawi-Fan in forum Kawasaki Cruisers
    Last Post: 04-15-2008, 09:17 AM
  2. Xenon Lights
    By dusty30 in forum Kawasaki Cruisers
    Last Post: 02-01-2008, 03:08 PM
  3. 100th Post!!!!!! Lightbar bulbs
    By jerkybear in forum Kawasaki Cruisers
    Last Post: 01-19-2008, 10:30 PM
  4. Is Yy Lightbar Causing Alternator Problem?
    By ppark in forum Kawasaki Cruisers
    Last Post: 05-28-2006, 10:06 AM
  5. What replacement bulbs do I need for my 7R?
    By 2002ZX7R in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 04-12-2006, 10:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
