grinding noise from starter clutch??? under LH CC cover (alternator):
I replaced the large starter sprocket, starter chain, and small sprocket of the starter assembly because the starter chain was slipping over the large starter sprocket. but still here a grind when i hit the start button like the starter clutch is slipping...but engine partially turns over *I had the starter clutch off and it looked perfect, it also locked tight when i turned it back.... *how do you know if the starter clutch is broken?...the engine turns over for awhile and then slips w/ a grinding noise? does that mean its shot...its sipping due to a lubrication issue..tried that, still not 100% sure its the clutch that's slipping http://www.kawasakimotorcycle.org/fo...ter-clutch.jpg Must you replace the entire clutch or can you buy the pieces (springs, rollers, etc.) and redo the clutch thanks for any help |
| kz 400 starter on a kz 440? | Alibi | Vintage Motorcyle Info | 8 | 09-30-2008 09:27 AM |
| KZ550 Starter Clutch? | lhemrick | The Mechanics Corner | 3 | 04-29-2008 04:09 PM |
| WANTED EX500 Starter Clutch | Dman007 | Accessory Swap Meet | 0 | 05-16-2007 03:52 PM |
| Brand New 87 - 93 EX500 Starter Clutch | Crux | Accessory Swap Meet | 4 | 06-26-2006 10:08 AM |
| EX500 Electrical / Starter Problem | shipbldr2000 | The Mechanics Corner | 8 | 05-12-2004 07:29 PM |
