Old 05-13-2008   #1 (permalink)
motofiend
motofiend's Avatar
Default Help Removing 82KZ550LTD Carbs
Hey I just recently acquired an 82 KZ550LTD, and need to clean the carburetors really bad. Does anyone know the best way to attack them? I have taken the gas tank off and removed the seat. I'm guessing that using a hair dryer to heat up the tubes coming off the air filter would help to get them to give a little bit, but I have no clue on how to remove the carbs themselves, since all four are hooked together...HELP... anyone?
motofiend is offline   Reply With Quote
Old 05-13-2008   #2 (permalink)
A2rider
Beserker biker woman
A2rider's Avatar
You'll have to loosen the clamps next to the motor, probably with a Phillips screwdriver. Heating them up a little will help before you take the carb BANK (all 4 of them together) off. You'll have to wiggle them gently, up and down and back and forth to get them off.
I am short enough and ugly enough to succeed on my own.
- Woody Allen
A2rider is offline   Reply With Quote
Old 05-13-2008   #3 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
The method I use is once you get the airbox rubbers soft and the clamps on the front side loose, collapse the top of the airbox tubes down till they pull off of the carbs on the top. Now do a up/down rocking motion on all 4 as you pull back on them. Keep working them back with the back end angled slightly upward till the front just clears the holders, then slide them out to either side. When about half way out you should be able to get to the throttle cable/s and disconnect them then bring the carbs the rest of the way out.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 05-14-2008   #4 (permalink)
motofiend
motofiend's Avatar
Thanks guys/and gal... Your input worked great...
1989 ZX10 Carbs Ninjawarrior The Mechanics Corner 2 08-13-2007 09:50 AM
Carbs: cross-referencing tricksrforkids The Mechanics Corner 5 09-27-2006 10:19 PM
94 ZX-7 Will not idle after cleaning carbs... lo cash john The Mechanics Corner 3 09-03-2005 02:47 PM
Takin' some of the mystery out of the carbs Shipwreck Kelly Vintage Motorcyle Info 1 01-14-2005 04:32 AM
KZ 650B Removing carbs.... Britcheflee Main Lobby 3 10-05-2004 01:19 AM
