Old 05-14-2008   #1 (permalink)
Courage314
Courage314
Courage314's Avatar
Default Master cylinder cap screws seized!!!!
Hey all,
Allen from Saint Charles, MO again. I have now gotten to the part where I bleed the front brake on my 1983 KZ550. Well, I have a problem. The screws that hold the cap on the master cylinder are seized. I cannot get them out. I tried the phillips until the phillips slots were strained. I also tried making the screwdriver slots wider with a dremel and using a larger phillips. I cut a slot in the tops and still was unable to get them out with a flat head. I have tried just about all the techniques I know. I am to the point of drilling them out or replacing the master cylinder. What's the general census. I know brakes are important and only the best will do so I am leaning on just replacing the master cylinder in a couple of months instead of bleeding. Thanks in advance.
Allen
My name is Allen, and my blood is primarily made up of 93 octane.
83' KZ550
99' VS800 Intruder
Courage314 is offline   Reply With Quote
Old 05-14-2008   #2 (permalink)
CanadianNinja
try a screw/bolt remover before you bust out the drill bits. the screw shouldn;t be this tough, do you know if it was loctited?
CanadianNinja is offline   Reply With Quote
Old 05-14-2008   #3 (permalink)
A2rider
Banned
Try an impact on it also. I feel your pain, replaced most of my Phillips bolts with allen heads.
If things do go wrong, I bought my master cylinder from a guy on Ebay. PM me if you want the sellers name.
A2rider is offline   Reply With Quote
Old 05-14-2008   #4 (permalink)
StarGate
StarGate's Avatar
Mine did the same thing last spring. I used a chisel and hammer to cut a groove in the side of the screw. Then used a blunt tip punch in the notch I created and hammer to break the screw loose so I could turn it with a screwdriver. After that, I completely rebuilt the MC and added 2 stainless socket head screws to the cap. Now this spring I changed the style of handlebars and had to buy a brand new MC to fit them after all that.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
StarGate is online now   Reply With Quote
Old 05-14-2008   #5 (permalink)
OKC_Kent
Riding every day!
OKC_Kent's Avatar
If you use an impact don't beat too hard, I believe yours is a plastic reservoir? When you get it off spread a little anti seize on the new screws.
Oklahoma City
'78 KZ 650
'83 KZ 750
Proud Marine Corp Dad
OKC_Kent is offline   Reply With Quote
Old 05-14-2008   #6 (permalink)
Courage314
Courage314
Courage314's Avatar
Thanks for the input. I'm headed to take on this problem with some of the ideas I just got from here. I'll fill you in when I'm done. Everyone have a good day.
Allen
83' KZ550
99' VS800 Intruder
Old 05-14-2008   #7 (permalink)
A2rider
Banned
Good luck. The new one I got is metal, let me know what happens.
Old 05-14-2008   #8 (permalink)
Kawa 1982
US Army, Retired
Default Hand Held Impact Screwdriver
I had exactly the same problem on my KZ1100 A2. Three sharp raps with a hand held screw driver did the trick. As some one said earlier put stainless steel screws in with anti seize compound. You will still need the hand held impact screw driver to get the screws out.
It is not the "Quantity" but rather the "Quality."
Kawa 1982 is offline   Reply With Quote
Old 05-14-2008   #9 (permalink)
Courage314
Courage314
Courage314's Avatar
Hey all, I finished the job. I was able to make an extra deep flathead slot on the stuck screws, and using the hand impact driver I busted them loose. I was able to finish the job, install new screws with anti-seize, and restore my brakes to perfection with synthetic Dot 3. You all rock!!! Love the help!!! Thanks again.
Allen
83' KZ550
99' VS800 Intruder
Old 05-15-2008   #10 (permalink)
Kawa 1982
US Army, Retired
Default Thanks
for letting us know you made it.
Old 05-15-2008   #11 (permalink)
A2rider
Banned
Good for you! We'll keep trying to help, if we can.
81 Kawi LTD 750 Rear Master Cylinder Gonzo3 The Mechanics Corner 2 05-23-2008 03:12 PM
Bleeding master cylinder Grrrrr... luvmyGPz The Mechanics Corner 8 03-10-2008 06:17 PM
Need A Master Cylinder For Z1-r Doc717 Main Lobby 1 10-27-2007 11:38 PM
front master cylinder swap rlibby Vintage Motorcyle Info 3 08-16-2007 08:14 PM
Stuck master cylinder screws? Alibi Vintage Motorcyle Info 17 02-26-2007 09:33 PM
