Old 05-15-2008   #1 (permalink)
kxrunner_86
Default 1986 kx125 dies when hot....
my 86 kx125 runs hard when cold but once it gets hot it just dies..i just changed the stator and now im thinking the coil is partially fried..?
kxrunner_86 is offline   Reply With Quote
Old 05-16-2008   #2 (permalink)
Stormdragon
Can't find time to ride
Stormdragon's Avatar
Or you have a light seize on the piston. Try pulling the head and looking at the bore.
It's not how fast you go, it's how little you slow.
Stormdragon is offline   Reply With Quote
Old 05-16-2008   #3 (permalink)
ronin1959
ronin1959's Avatar
If she dies just like hitting the kill switch, test the ignition coils and the pulser coils for resistance when cold and then again when she dies. Your manual will tell you the resistance service limits. You'll probably find them within limits when cold but off the chart when she dies.
Had the same problem with my Z900 and it turned out to be the pulser coils going open circuit when the engine warmed up.
HTH, Ronin
ronin1959 is offline   Reply With Quote
Old 05-16-2008   #4 (permalink)
kxrunner_86
alright ill check that out..thanks
1986 kx125 dies when hot.... kxrunner_86 Kawasaki Motocross and Offroad 4 05-16-2008 03:42 PM
does anyone know if 93 KX125 parts will fit 86 KX125? simka Kawasaki Motocross and Offroad 5 01-15-2008 01:35 PM
Deron got creative yesterday 1400pilot Main Lobby 224 09-09-2007 11:19 PM
KZ1000 dies when hot? jcmartin86 The Mechanics Corner 5 08-15-2007 09:55 PM
1986 Kx125 Zach_KDX250 Kawasaki Motocross and Offroad 7 07-29-2006 11:08 AM
