Old 06-23-2008   #1 (permalink)
Kenny J
Default 73 Z1 Throttle / Carb Issue Need Help!!
I'm new to the forum and figured I'd ask here first for help. I have a 73 Z1 that I've owned for over 30 years. It had been sitting for some time and I finally got it running again awhile ago. One of the issues I had before was that the throttle would stick WFO, sure would get my attention. I physically had to push down on the carb linkage to get it to release. I decided to rebuild the carbs and found the slides were sticking terribly. I rebuilt them and found everything to be working properly again (I also changed the throttle cables and carb intake rubbers). Once I got the bike running again the throttle response worked but now if I rev it while sitting in neutral or riding the bike just continues to rev up with no throttle increase. I pushed down on the linkage as before but it doesn't slow the rev's. It's almost like a vacuum problem or something. BTW, I haven't vacuum sync'd them yet, could this be the issue? I'm stumped and sure could use some help..........
Thanks in advance,
Kenny J
Kenny J is offline   Reply With Quote
Old 06-23-2008   #2 (permalink)
LoudFastUgly
Got KZ?
LoudFastUgly's Avatar
Pods or stock air box?
KZ550A4
LoudFastUgly is offline   Reply With Quote
Old 06-23-2008   #3 (permalink)
Kenny J
Stock air box..........
Old 06-24-2008   #4 (permalink)
StarGate
StarGate's Avatar
Make sure the carbs are seated all the way in the manifolds and that all clamps are tight. Check for missing or cracked vacuum caps/lines. Also check the throttle cable adjustments. You should have a little free travel on the throttle before it starts to move at the carbs.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Bayou 300 carb problems antiqucycle Kawasaki ATV and Mule 102 1 Day Ago 10:37 PM
GPX750R - carb question? qzak Vintage Motorcyle Info 10 04-09-2008 05:43 AM
Carb Adjustments? Dare Vintage Motorcyle Info 9 09-27-2006 09:45 PM
Overflowing Gas issue apsteinberg The Mechanics Corner 1 09-08-2006 11:06 AM
96 Vulcan 1500 heavy throttle hesitation suzracer10 The Mechanics Corner 8 08-25-2005 11:04 PM
