Old 06-26-2008   #1 (permalink)
AK82kz440
To much ice on the roads
AK82kz440's Avatar
Default Kills when starter button released???
Well I've got things pretty much back together on the 85 Vulcan 700 but...
I replaced the battery and attempted to start the bike. It fires when the starter button is pressed but kills immediately when the button is released. I pulled the plugs both front and back have spark. Checked connections all seem to be good, used electrical contact cleaner on the contacts.
Don't know where to go now, Any ideas
On a side note, while tracing wires I found the clutch safety switch will not allow the starter to engage when the clutch lever is fully pulled. Don't know what to make of this. Now With the bike in gear and the clutch lever pulled the rear wheel won't roll (still in gear). To my pea brain this part sounds like a clutch job, right?
Any help is appreciated
Thanks
I see your playing stupid again...
looks like you're winning too!
AK82kz440 is offline   Reply With Quote
Old 06-26-2008   #2 (permalink)
AK82kz440
AK82kz440's Avatar
Any Ideas
Old 06-26-2008   #3 (permalink)
A2rider
Banned
I wish I could help, but this is beyond me. Hopefully Stargate or Andy will know more about it and can help.
You pulled the start button housing and cleaned in there?
A2rider is offline   Reply With Quote
Old 06-26-2008   #4 (permalink)
AK82kz440
AK82kz440's Avatar
Thanks Tina, I'll go back over that tonight and re-clean that area.
Old 06-26-2008   #5 (permalink)
A2rider
Banned
Put some dielectric grease in there, too.
You're obviously getting a contact, but somewhere it's not letting it release when you take your finger off of it.
Old 06-26-2008   #6 (permalink)
OKC_Kent
Riding every day!
OKC_Kent's Avatar
I know I heard of this problem before, on some forum. The engine runs as long as the button is pushed, but dies when released. Give us time, someone may have an answer, meanwhile I'll search the forums I'm on for that problem.
Is it possible your power to the coil is coming from a relay? Maybe from the starter relay or the headlight relay?
Oklahoma City
'78 KZ 650
'83 KZ 750
Proud Marine Corp Dad
OKC_Kent is offline   Reply With Quote
Old 06-26-2008   #7 (permalink)
dutch724
Just trying to learn :)
dutch724's Avatar
Is the starter still cranking while the engine is running and your holding the start button?
dutch724 is offline   Reply With Quote
Old 06-26-2008   #8 (permalink)
AK82kz440
AK82kz440's Avatar
Yes the starter cranks and the engine sounds like it's running, when the starter switch is released the engine dies/won't run. I now know what the Valcon riders refer to as the "big bang"!! I see I'm gonna have to do some marbeling (I can't hear right now but I can still see).
Charlie
Old 06-26-2008   #9 (permalink)
taro
Wants better weather!
And the fuel system and air filter are clean and operating properly?
taro is offline   Reply With Quote
Old 06-27-2008   #10 (permalink)
AK82kz440
AK82kz440's Avatar
How would I check if the power for the coils was coming from a relay?
Old 06-27-2008   #11 (permalink)
AK82kz440
AK82kz440's Avatar
Fuel system was completely cleaned from tank to carb with inline fuel filters placed on fuel lines, air system was gone thru, new filters installed.
As I see it right now I've got three problems to deal with before I can get out to ride it:
1) Engine not staying running after starter disengaged, bike seems to be running then dies when starter button let go of.
2) Switch not allowing bike to be started when clutch lever is pulled in all the way, pin is not touched by clutch lever not allowed to crank starter.
3) Clutch not engaging, not allowing back tire to roll when clutch lever pulled in. Tire spins freely when in neutral, but when in gear with clutch pulled in no-go. For this I believe I'm going to have to do a clutch job (only way I see around it)
Old 06-27-2008   #12 (permalink)
StarGate
StarGate's Avatar
For #2. If it's not allowing the the starter to work how are you coming to the conclusion you reached in #1?
For #3. First thing to check is the clutch adjustment. Second thing is that some times when bikes sit the clutch plates will stick together. You may be able to put it in gear then pull the clutch lever in and rock the bike back and forth to try and break them free. If this doesn't work then you'll probably have to pull the plates out and clean/replace them.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 06-27-2008   #13 (permalink)
AK82kz440
AK82kz440's Avatar
With the bike in neutral clutch lever released, starter will turn bike over, sounds like it starts, release starter button bike dies. Bike in neutral clutch lever pulled in starter button pushed - nothing. Sorry if I'm not making things clear, I'm trying. Thanks again for all the assistance.
Old 06-27-2008   #14 (permalink)
OKC_Kent
Riding every day!
OKC_Kent's Avatar
Some people power their coils with a relay, avoiding the round-about route of supplying power to them by the stock, old, wiring system, which can (in older bikes) not supply 12v to the coil... It's a long process to fully describe but since I don't know the history of your machine it's a suggestion just put out there for you to check on. I was thinking if the coil power wire was hooked to the wrong pole of a relay, like the starter or headlight relay, then they would lose power once the start button is released.
In the meantime, locate the coil and set the meter to DC and see if you get approximately 12volts at the power wire when you turn it over, and see if there is no voltage when you release the starter button. This all may be related to your clutch switch too, but I don't have a wiring diagram to see. We want to eliminate a no-power situation to the coil as a cause.
Another thing I might try is to pull off the clutch switch wires and jump them together, then try to start it.
Does this bike normally have a kickstand safety switch?
Oklahoma City
'78 KZ 650
'83 KZ 750
Old 06-27-2008   #15 (permalink)
StarGate
StarGate's Avatar
Has this bike ever run since you've owned it? It sure sounds like someone has gone in and hosed up the wiring and/or substituted incorrect parts on it.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 06-27-2008   #16 (permalink)
AK82kz440
AK82kz440's Avatar
Bike hasn't run since I've owned it but if they hosed the wireing system they did an excelent job of it because I don't see any signs of splices or splitting of wires. I'm leaning towards a switch or relay being out or the unthinkable me getting senile and hooking things up wrong . OK, OK more senile.
Old 06-27-2008   #17 (permalink)
StarGate
StarGate's Avatar
Well the clutch switch operating in what seems to be reverse could be done if they substituted a normally open switch for a normally closed switch. I'm not even sure how you could do this by switching the wires around.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
2001 ninja 500 starter button inop, need diagrams dastang2 Kawasaki Streetbikes/Sportbikes 2 04-07-2008 11:15 PM
starter relay trouble shooting daseth The Mechanics Corner 12 01-02-2008 05:08 PM
Starter? Kawa 1982 Vintage Motorcyle Info 7 08-29-2007 10:12 PM
bike dies when releasing the clutch pcz87ninja The Mechanics Corner 11 07-15-2007 02:57 PM
'90 Ninja zx10 - press starter button and nothing happens jswalt The Mechanics Corner 2 10-18-2004 06:29 AM
