LinkBack | Thread Tools |
Hi All
Newbie here, Nice to know a place to get information, Thank you. I'm also a newbie with the engine displacement (used to riding smaller MCs, & cars). I have this 90s model Balius 250cc, maybe someone can give some help with this hard start issue that this MC is having. It looks like it's electrical since I took it to a Mechanic and he tried about 2 new Batteries with same results. He is thinking that it could be the starter (bushings). The Starter he said sounds it doesn't spin as fast as it should. Could it be a wiring problem too? BTW if someone can also please give any Mechanical maintenance tips as well Thank you so much. |
Beserker biker woman
![]() Join Date: Mar 2006
I can't help, but if you have a picture of this incredible machine, could you post it? And does it really redline at 21k?
I am short enough and ugly enough to succeed on my own. - Woody Allen |
Wow, I hope it does but don't think it will reach that high, not even half
Here's a link Search Kawasaki Balius - Wikipedia, the free encyclopedia Last edited by j813 : 07-02-2008 at 06:23 PM. |
#4 (permalink) |
I just found this model a week ago. It was never offered in the States, but I would love to see one in person. It has everything I would want in a dream bike.
#6 (permalink) |
Got KZ?
The starter is grounded to the engine by nature of the mounting bolts. The main ground wire from the battery to the frame of the bike is the most important. Make sure it is clean (sandpaper or emery cloth) and tight enough that it can't be moved by tugging on it.
http://www.kawasakimotorcycle.org/fo...ing-guide.html Get a manual. Buy one. Borrow one. Steal one. You shouldn't be allowed to own a motorcycle without one. If your starter solenoid has burnt tips, you may have a slow starter, though it is unlikely. Good luck.
KZ550A4 |
#7 (permalink) |
Will again continue find that needle on the i-net. Still looking for a manual.
I was hoping someone could point the way how this starter can be removed. Maybe this engine has a twin or has similarities. Someone told me it could be the starter carbon brush needs replacement. Here's the pic of the side of eng where the starter is http://i6.photobucket.com/albums/y24...g?t=1215102928 Where do I point the gas valve at? http://i6.photobucket.com/albums/y24...g?t=1215104465 A2rider Is the one you're asking? ![]() Last edited by j813 : 4 Weeks Ago at 11:24 AM. |
#8 (permalink) |
Navy Vet S.A.R. crew
You have the gas valve on RES which means if you run out of gas you're stuck where you are. Normal running should be pointing straight down to RUN. Then when you start to run out of gas you can turn it to RES and head to the nearest gas station. Turn it 180 degrees.
#9 (permalink) |
You're evil! The speedo/tach photo is great, but can you please, pretty please take a picture of the whole bike?
They would make a bike I have a snowball in hell's chance of ever owning............
#10 (permalink) |
Guys I may have done something bad
I used a car engine coolant ("Whiz" by Malco, color red) Is it too strong for a motorcycle? Here's a pic, on bottom right it ate the sealant http://i6.photobucket.com/albums/y24...g?t=1215128921 A2rider Here's one shot I took same time 7hours ago, I'll take a shot again later http://i6.photobucket.com/albums/y24...g?t=1215129350 Last edited by j813 : 07-03-2008 at 06:57 PM. |
#17 (permalink) |
Thanks
I think sprockets I have are 16t and 40t. I guess this MC isn't really designed for speed Am thinking replacing the headers since their rusty and clutch sliding, I may worn out the clutch line since am afraid of engine turning off since it wont start. Although I may have fix the problem by grounding the Batt on the frame. |
#18 (permalink) |
My mechanic found a clicking sound when the rpm reaches about 8k-above
He said it needs a Camshaft repair, cam chains I recently put fully synth oil 10w-60, 320ml friction modifier PERTUA.COM - PER'TUA Changed Oil Filter using one that matches the thread (Part15400.PLC.004) For Honda Civic, Accord, etc. http://japanautomobileparts.com/imag...805%20a002.jpg Clicking sound still there, but maybe it's less noisy. Can I still safely use it, put the engine at high revs? about 11k rpm Thanks Last edited by j813 : 4 Weeks Ago at 11:30 AM. |
| ZX6R hard to start | ylwf3ve | Kawasaki Streetbikes/Sportbikes | 1 | 06-12-2008 12:25 AM |
| 2005 750 vulcan hard to start when cold | Tom Austin | Kawasaki Cruisers | 15 | 11-08-2007 02:32 PM |
| Hard Start COLD | motoxracer | Kawasaki Streetbikes/Sportbikes | 9 | 05-01-2007 08:38 PM |
| Ninja hard start ???? | motoxracer | Kawasaki Streetbikes/Sportbikes | 1 | 04-28-2007 02:52 PM |
| Hard to start when cold... | mpoertner | The Mechanics Corner | 3 | 03-03-2005 10:54 AM |
