LinkBack | Thread Tools |
#22 (permalink) | |
I disagree. i am having this problem with my '91 ex500 and when i put a screwdriver across the posts of the relay all i get is a nice big spark when the screwdriver touches both posts....not from my plugs, from the screwdriver...any help on that issue? bad starter motor? |
#25 (permalink) |
my bike clicks when i push the start button, just doesnt turn over...it also clicks and sparks when i touch the screwdriver to the solinoid but again, doesnt try to turn over...i will be trying to jump my starter tonight...long with trying to jump my solinoid too...with car bat so wish me luck...
#26 (permalink) |
First Ninja and lovin it
good luck, my battery was dyin from working on my bike and only letting it idle...(was adjusting my carb) so I grabbed some jumpers and strapped them to a car battery.. worked fine. But yeah try firing it up at the solenoid and let us know how it goes.
#29 (permalink) |
Wants better weather!
A inexpensive replacement for the starter solenoid can be found at the riding mower repair shops. Most bike shops want $100 for the solenoid while at the mower shops it's about $15.
Remove your old one and visit the repair shop and match up with what they have. Maybe a little wiring mod is needed but look at the money not spent! |
#30 (permalink) |
Forensic Bug Splatter Analyst
You have pulled out the battery? Checked it for fluid? Levels good and no crap on the + and - terminals?
Sounds like a battery issue to me.
1984 Ninja 900 (A1) To make it go faster I need to add more lightness! |
#31 (permalink) |
ok..pulled the plugs out tried starting it and nothing. I tried to jump the bike straight to the starter with the plugs out and still nothing...i also tried to put the bike in 2nd gear on the center stand and manually spin the back tire and i can't turn it. I also tried to jump the bike with a car bat since my bat is about dead now and i dont seem to be getting spark to the plugs either.....??????? what next?
i have previously taken the bat down to my local bike shop and they charged it up...i have tried however to jump from the bat out of my altima and still nothing.... |
#32 (permalink) |
no...i am not sure the engine isnt locked up...im hoping it isnt...what to do if so??? the bike was running fine but after about 15 miles into riding it would feel like it was running out of gas even though there was gas. I traced it to a pinched tube... it was the tube that goes inbetween some piping inbetween the carbs...when i blow on it i hear bubbling in the carbs...seems to be an air inlet into there. but im not sure that was the problem because while i was checking all of this i left the petcock on over night....it flooded but i didnt realize until i tried to start it and heard a pop...that has happened in the past but i just take the plugs out start it..it blows the gas out of the cylinder, i put the plugs back in and im good...not this time...
#33 (permalink) |
How in the hell could the bike flood? Your carbs work like a toilet tank and as the fuel fills the bowls a "seat" seals off the flow of gas from the tank. If your floats have failed you and gas managed to flow past them into the engine and flood one of the cyclinders and then you tried to start it? That could be a problem.
Look, my advice and please PM me with the results. Remove your left side lower cover to expose the crank end nut. With the plugs removed and the trans. in "N" place a socket and a long bar on there and try to turn it counter clockwise. Let me/us know. If you can not turn it you may have some bigger issues to deal with.
#34 (permalink) | |
You mention it sat for a year prior to you starting it? It was drained of gas? Your fuel tap, does it have an "off" setting?
#36 (permalink) | |
#37 (permalink) | |
Navy Vet S.A.R. crew
| The age-old question - Ninja 250 vs Ninja 500 | CaseLogic | New Rider Forum | 15 | 08-27-2008 07:14 PM |
| vulcan 500 vs ninja 500 starter motor? HELP! | snakegoat | Kawasaki Cruisers | 1 | 03-29-2008 09:17 PM |
| Long days on a Ninja 500? | Dave'sEX250F6F | Kawasaki Touring and Sport Touring | 14 | 02-07-2008 05:41 AM |
| metal noises when i start my ninja 250?? | xena24 | Kawasaki Streetbikes/Sportbikes | 4 | 12-17-2007 03:19 PM |
| WTB: Ninja 500 or 250 within 500 miles of Houston, TX | Monjoho | Streetbikes Buy/Sell/Trade | 1 | 05-12-2007 03:54 AM |
