Old 07-06-2008   #1 (permalink)
backontheroad
Smile 1981 440 ltd carb question
hey guys i just bought a 1981 440 ltd in great shape for just over 600.00 only has 10,000 miles on it looks good and runs great my question is when the motor isnt running one of the carbs drips a drop of gas about every 3-4 minutes out of the overflow tube the guy i got it from told me about this and said there was an o-ring inside there that needed to be replaced and he couldnt find the ring localy or he would have changed it. it doesnt drip when the bike is running or when you are riding it only when the bike is sitting any idea's? i am gonna take the bowls off this weekend as soon as i get room cleaned out in the shop to check it out and have a look see just thought i would see what you guys thought . the bike runs excellent other than that
backontheroad is offline   Reply With Quote
Old 07-06-2008   #2 (permalink)
StarGate
StarGate's Avatar
Float height is off or the float valve is dirty/worn.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
StarGate is online now   Reply With Quote
Old 07-06-2008   #3 (permalink)
backontheroad
ok i have had carbs apart before not on this bike but on others can i bend the part that holds the needle to adjust height or do i need to buy a kit of some sort to fix . also the valve is the one the needle goes up into or something else it will be this weekend before i take it apart just trying to get a heads up on what to look at and thanks for your quick response
Old 07-06-2008   #4 (permalink)
StarGate
StarGate's Avatar
Bending the tang on the float is how you adjust the height. You need to check the service manual for the proper float height. Yes that is the valve.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 07-06-2008   #5 (permalink)
backontheroad
thanks man i am gonna give the valve a good cleaning and check the hieght this weekend thanks for the advice
Old 09-17-2008   #6 (permalink)
MOTOXAZ
hey we are in the process of rebuilding the carb on my 1981 kawasaki 440. Does anyone know where to get the hoses that hold the carb onto the intake? They should be called carb holder hoses.
MOTOXAZ is offline   Reply With Quote
84 ZN1100 carb question hayward6 The Mechanics Corner 24 09-02-2007 03:40 PM
454 Carb question advcyc The Mechanics Corner 4 05-30-2007 10:43 AM
yet another Carb question wylde1 The Mechanics Corner 4 05-28-2007 01:01 PM
Carb Question WarX The Mechanics Corner 12 05-25-2007 10:34 PM
Another CVK carb question bradshjr The Mechanics Corner 1 03-19-2004 10:08 PM
