Old 07-07-2008   #1 (permalink)
JaceBror
Default Brake rattle
I have a 2000 vulcan 750 i just bought. when i use the front brake i hear a very slight rattle, it doesnt sound like it is from the brakes but almost like it is from the handle or maybe... the master cylinder. the brakes do seem a little weak like maybe they need to be bled. but i am used to a ninja which had strong front brakes.
eLi
JaceBror is offline   Reply With Quote
Old 07-07-2008   #2 (permalink)
69smu
could possably be the anti squeel shims on the back of the pads ratting around if so a dab of copperslip on the back of em will cure it mate ,
69smu is offline   Reply With Quote
Old 07-07-2008   #3 (permalink)
JaceBror
that would make sense
eLi
Old 07-15-2008   #4 (permalink)
JaceBror
yeah i totally took the brakes apart, and put some good lube everywhere you should and still rattles. I didn't have any DOT4 around, but when i do they are gonna get bled dry.
eLi
Old 07-15-2008   #5 (permalink)
LoudFastUgly
Got KZ?
LoudFastUgly's Avatar
If I were feeling mischevious i'd say that's the metric cruiser alarm, keeps you from falling asleep completely.
Fortunately I'm not.
Does it have a floating caliper setup?
KZ550A4
LoudFastUgly is offline   Reply With Quote
Old 07-15-2008   #6 (permalink)
JaceBror
errrrr not quite sure what that means. the pad that backs up to the piston is held down in place by some spring clips, and the other pad slides on posts. I lubed those posts, and all the little spring clips, and the backs of the pads where they touch either the piston or back side of the caliper holder.
eLi
Old 07-15-2008   #7 (permalink)
LoudFastUgly
Got KZ?
got a pic?
KZ550A4
Old 07-15-2008   #8 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
I hope you used a high temp grease thats not going to turn liquid and run when it gets hot. If your lube gets into the wrong spot that can make for some exciting rides.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 07-15-2008   #9 (permalink)
JaceBror
I do have a pic but for some reason i cant post any pics. to any site not jsut this one.
eLi
Old 07-15-2008   #10 (permalink)
JaceBror
Yes i used good grease, stuff made for brakes
eLi
brake shoes rattle cheap1 Vintage Motorcyle Info 5 05-08-2008 09:35 AM
Bike-a-holics quick and easy brake bleeding guide Spok Projects and "How To" Write Ups 6 03-02-2007 10:43 PM
bleeding... kscubb Kawasaki Cruisers 5 02-27-2007 03:37 PM
Brake pad rattle kwakbloke The Mechanics Corner 1 06-18-2006 03:15 PM
EBC Brake Pads and brake questions ? tcobar Kawasaki Cruisers 6 07-26-2005 09:39 AM
