No power to the wheels
+ Reply to Thread
Results 1 to 9 of 9
Thread: No power to the wheels
  1. #1
    Join Date
    Jun 2008
    Posts
    14
    Default No power to the wheels
    The bike (97 zx-6r) died. Figured it was gas, now the engine runs fine after getting gas.
    I can rev the engine, but when I start to release the clutch, the engine dies.
    I'm kind of a noob and just started with the DIY. Not mechanically inclined but trying to fix that. Bought the manual a few weeks ago, started with some regular maintenance type stuff.
    Any suggestions for a starting point.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Member BTK Expert
    Join Date
    Mar 2006
    Location
    KCK
    Posts
    19,728
    Is the kickstand up?
  4. #3
    Join Date
    Jun 2008
    Posts
    14
    Yes the kickstand is up. When ever the clutch is slightly released, the engine dies.
  5. #4
    Join Date
    Jun 2008
    Posts
    30
    kickstand switch is probably malfunctioning. does it die because of load or does it die like the ignition was turned off?
    if it resembles turning off the key, check your kickstand switch.
  6. #5
    2007 Ninja 650R BTK Intermediate daniel2002p's Avatar
    Join Date
    Jun 2008
    Location
    Ft Worth, TX
    Posts
    244
    Quote Originally Posted by 97tjtom View Post
    +1 if you relase the cluctch in neutral does it still die?
    D
  7. #6
    Join Date
    Jun 2008
    Posts
    14
    You guys are amazing. I did nothing more then "fiddle" with the kickstand area. (Cleaned the area around the kickstand basically) Started her up, no problems. Thanks for the help.
  8. #7
    Got KZ? BTK Expert LoudFastUgly's Avatar
    Join Date
    Oct 2007
    Location
    Ontario Kanata
    Posts
    934
    Damn it you guys, how many times have I told you I NEED a donor zx6 to make my KZ into a streetfighter?
    Jeez!
    KZ550A4
  9. #8
    Member BTK Expert
    Join Date
    Mar 2006
    Location
    KCK
    Posts
    19,728
    Quote Originally Posted by LoudFastUgly View Post
    Jeez!
    And you wonder why people don't trust you!
  10. #9
    Join Date
    Oct 2007
    Location
    Ontario Kanata
    Posts
    934
    Sorry, sometimes I'm overcome by my need to build my streetfighter. I will 'try' to be helpful to the ZX6 guys. At least the post 2000 ZX6 guys
    Besides, All i need is a complete front end with brakes, rim and tire plus a complete swing arm assembly with rear rim and tire (preferably new front and rear tires) with rear sets and master cylinder. I'm sure I can pick that up cheap...
    KZ550A4
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Fuse block and power outlet install.
    By mshumate99 in forum Kawasaki Cruisers
    Last Post: 05-03-2011, 07:13 AM
  2. carb backfire? 82 750 twin
    By toyman1156 in forum Vintage Motorcyle Info
    Last Post: 06-02-2008, 11:04 PM
  3. 95 500 Ninja... Power Loss?
    By Jasonx in forum The Mechanics Corner
    Last Post: 01-17-2007, 02:26 AM
  4. power
    By johnnyb315 in forum The Mechanics Corner
    Last Post: 11-25-2006, 06:45 PM
  5. Will ZXR wheels fit the 250?
    By makenzie71 in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 02-07-2005, 05:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
