Rust in gas tank
+ Reply to Thread
Results 1 to 20 of 20
Thread: Rust in gas tank
  1. #1
    Join Date
    Jul 2008
    Location
    Berkeley Heights, New Jersey
    Posts
    19
    Default Rust in gas tank
    Anybody have advice for cleaning rust out of a gas tank? The speed shop i take it to, said they could send it out for 100 bucks and have it cleaned, but i saw a 3 stage kit at my dealer that cleans tanks. Wondering if that would be any good.
    Any products to recommend ?
    "there is absolutely no excuse for what I'm about to do"
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Member BTK Expert
    Join Date
    Mar 2006
    Location
    KCK
    Posts
    19,728
    POR 15 works well, but it's a PITA. I'd let somebody else do it.
  4. #3
    Got KZ? BTK Expert LoudFastUgly's Avatar
    Join Date
    Oct 2007
    Location
    Ontario Kanata
    Posts
    934
    If your's has good paint and is dent free, pay the hundred!!!
    KZ550A4
  5. #4
    Wants better weather! BTK Expert fitbmxseries1's Avatar
    Join Date
    May 2007
    Posts
    804
    nothing a bottle of muratic acid and a section of chain wont fix.
    that is how we do tanks at my work. Clean out the tank with soap and water, pressure wash as much rust out as you can. Let dry. Plug all holes then fill with acid, put good size section of chain in the tank and roll it around, the chain will rub the rust off and the acid should desolve what ever is left. Then wash and flush the tank out. let it dry again and you should be good to go. You can buy the acid at any hardware store that sells pool supplies.
    I could be a tall horse jockey but horses are too slow.
  6. #5
    Navy Vet Search & Rescue BTK Expert StarGate's Avatar
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,890
    I tried cleaning mine a couple of times but the rust came back both times. I finally used the POR 15 kit and have been very pleased with the results. It does require 2x 30 minute sessions of rolling the tank every little bit to keep the entire inside surface coated but it was well worth it IMO. Mine is so good right now that I'm not even running an inline filter. I will go ahead and install one when I find the one I'm looking for just as a precaution. I've had the carbs off a couple of times since I used the POR and not even 1 speck of rust could be found in any of the carbs.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  7. #6
    Still On The Kickstand bluemotorcycles's Avatar
    Join Date
    Jul 2008
    Location
    KY
    Posts
    39
    lol I used to put gravel and gas in my old beater dirt bikes
    1991 ZX6-D
    If at first you don't succeed, look in the trash for the instructions.
  8. #7
    Join Date
    Jul 2007
    Posts
    39
    Default Rust
    Depends On How Bad It Is.if It's Minor Drain It Wash It With Dish Detergent And Rinse.put White Vinegar In (it's Mildly Acetic And Let Stand Till You See The Rust Is Gone Very Cheap Way And Safe On Paint.if It's Heavy Go To A Tractor Supply Store And Get Their Milk Stone Remover.mix 1 Part To 4 Water.safe For Paint And Very Effective. Then Do The Por-15.i Have A Report Written On It If You Want.
  9. #8
    Join Date
    Jul 2008
    Posts
    16
    I have a 1992 Vulvan left outside for 10 years. The entire surface of the inside of the tank is rusty from what I can see. Do you guys think I can fix it with the recommendations here?
  10. #9
    Join Date
    Jul 2008
    Posts
    16
    OK. I bought the Milkstone and it and the water are now in my tank after about 5 rinses with water. I will let soak overnight or longer if you recommend that??? Assuming this will work, which I'll be extremely grateful, what is Por-15 and where do I get it.
    FYI: 1 gallon of Milkstone cost $12.00
    Thanks yall - JP
  11. #10
    Join Date
    Jul 2007
    Posts
    39
    Default Msr
    Wow I pay $7.99 a gallon here.Did you wash the tank with detergent first to get rid of and oily residue? Leave it in at least a day if heavily rusted.You can drain it and strain it through cheese cloth and reapply to the tank until it's clean.Go to POR-15 Inc. it's a company in Morristown NJ. Email me at ripcbx1 at yahoo.com and I'll forward how I do the Por treatment
  12. #11
    Join Date
    Jul 2008
    Posts
    16
    Darnit, I didn't wash with detergent first. I estimate there having been 1 gallon of OLD gas in the tank, which subsequently burnt in a very oily fashion on an old stump. I did rince it thoroughly with a high pressure hose jet spray 5 or 6 times.
    Thanks for the Suggestion to strain the solution. Is it OK to leave it in there for about three days? I need to go out of town tomorrow.
    I'll check out the POR-15 ASAP.
    Thanks again!
  13. #12
    Join Date
    Jul 2008
    Posts
    16
    For my 3.9 gallon tank how much POR-15 do I need? Pint, quart, or gallon?
    Please don't say gallon because it's expensive...
  14. #13
    78 1000 JUNKIE BTK Intermediate keith1's Avatar
    Join Date
    Jun 2008
    Location
    Rhode Island
    Posts
    145
    are the 3 part creme kits no good?
  15. #14
    Join Date
    Jul 2008
    Location
    Posts
    19
    thanks guys i really appreciate all the responses. i think im just gonna have it cleaned in a couple weeks
  16. #15
    Join Date
    Jul 2008
    Posts
    16
    Also, how do I dispose of the diluted Milkstone?
  17. #16
    AZ's Official Mechanic BTK Expert QKENUF4U's Avatar
    Join Date
    Sep 2004
    Location
    lake havasu city arizona
    Posts
    4,973
    Quote Originally Posted by keith1 View Post
    they are a good kit (KREEM) but alot people dont prep correctly and the coating eventually comes off.
    ive done 3 tanks that way and never had a problem. anymore i will just use the first two parts of the kit and fill it with gas and use it.
  18. #17
    LEEHRAT Forum Supporter fmnnc's Avatar
    Join Date
    Jul 2008
    Location
    Oak Level, NC
    Posts
    47
    I feel your pain brother and have just completed the process. I read about Kreem and Red-Kote. I also went to a local radiator shop which guaranteed to mess up the paint which would mean a new paint job.
    After doing some more research on various web-sites and forums, I came across this stuff:
    My tank had a bunch of rust and crap in it. I followed the directions exactly and now my tank looks like new on the inside and is protected for life. I too was quoted big bucks to bail me out. This process will take some time but I had more of that than money. The "coating" takes four days to cure but it looks great. Check it out at Cycle Tank Sealer - Fuel Tank Sealer - Better then Kreem - KBS Coatings I am very satisfied. I am a shop teacher in a high school and am very particular when it comes to working on stuff. Again, I was very impressed with this product.
    Hope this helps and good luck. If you decide to go with this method feel free to contact me with any questions you may have. Also, get the large cycle tank kit for only a few more bucks. That way you know you will have enough sealer no matter what your situation.
  19. #18
    The Cruising Gunsmith BTK Expert
    Join Date
    Oct 2006
    Location
    California
    Posts
    1,459
    Kreme has been working in my tank for about 25 years now. Just be careful not to get the stuff or the fumes near the paint.
  20. #19
    Join Date
    Jul 2008
    Posts
    16
    Default Tank in use
    Well I used the Milkstone (soaked for 3 days) but there was still a shillak/gummy substance in a lot of places so then I used about a half gallon of Mineral Spirits soaking or 24 hours to no avail.
    Right now I put two fuel filters in line with new fuel hose and filled the tank up so it wouldn't rust before I get to use POR-15 but I'm hesitant due to the varnish/gummy just still in the tank. I figure the gas will help dissolve it over time and I'll coat it later.
    Do I even need to coat the tank???
  21. #20
    Join Date
    Dec 2012
    Posts
    1
    Default Re: Rust in gas tank
    Hi all, my experience with rusty tanks:
    I had my tank cleaned and sealed by "pro's" and one year later rusty again so I started
    doing them myself with great results.
    Like others clean tank and roll small pieces of metal, nuts,bolts etc around inside to get
    the scale off. I then used a product called "Metal Rescue". It worked great, looks like
    new inside and you can reuse it. It is fairly expensive but I was willing to pay the
    extra for something that works. ($25/gallon, $90/5 gallons).
    I reuse it for cleaning other parts as well. The nice thing is that it is water based so
    no fumes and easy to work with.
    Sealing the tank is another issue, I went to a local place for protective coatings and
    bought theirs, working well so far. after 4 years still no rust
    Hopefully this helps
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Gas tank clean out question
    By dapittboss in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 04-14-2008, 04:07 PM
  2. EX500 Gas Tank Cap bracket
    By Jex500 in forum Accessory Swap Meet
    Last Post: 04-13-2008, 07:26 PM
  3. rust in gas tank
    By aftermath4788 in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 08-12-2007, 07:30 PM
  4. Gas leak from the gas cap left brownish stuff on the tank
    By sqldosa in forum Kawasaki Cruisers
    Last Post: 06-19-2007, 09:30 PM
  5. Rust in the gas tank
    By 79batmobile in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 08-03-2005, 07:49 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
