Old 07-17-2008   #1 (permalink)
thomaswinton
Default spectre needs help BAD!!
The bike......1983 750 spectre..........the problem, from 3000 to 6500 the bike is missing on 2 cylinders under load and won't go faster than 6623, I need a test method for the igniter and ignition pickup and a general idea as to what to check and parameters to test readings. I have a auto ranging multimeter and all the tools a man would need. I just don't have the specs. I can't get a book since the bike don't run and it's all I had running to get to town. please help!
former owner and rider of a Hardley Davidson
88 1200 sportster
99 ZX9-rr
the kawi spectre
thomaswinton is offline   Reply With Quote
Old 07-18-2008   #2 (permalink)
shadelane
pickup coils----360-540 ohms
at the IC igniter between pins 1 and 9 for cylinders 1 and 4
pins 2 and 8 for cylinders 2 and 8
infinity between ground and pins 1,2,8 and 9.
Timing advance is electronic 10 degrees at idle and 40 degrees 3300-3900 rpm
coils 1.8-2.8 ohms primary. 10,000-16,000 secondary. infinity between primary and secondary wires
shadelane is offline   Reply With Quote
Old 07-18-2008   #3 (permalink)
LoudFastUgly
Got KZ?
LoudFastUgly's Avatar
I'm sure you already know this, but spray header pipes with water to determine which two are running and which two are not. Water will stay longer on the colder (not running) pipes.
KZ550A4
LoudFastUgly is offline   Reply With Quote
Old 07-18-2008   #4 (permalink)
herk
bustedfeet
herk's Avatar
delete
herk is offline   Reply With Quote
Bad timing & bike shopping Tweek Kawasaki Streetbikes/Sportbikes 3 06-03-2007 10:25 PM
Man shot dead for bad singing in Philippine karaoke bar Bad Company Off Topic 4 06-03-2007 01:36 AM
Bad News Today Hilts Main Lobby 44 12-21-2006 02:47 PM
i am a bad bad man. Ninjeff Kawasaki Streetbikes/Sportbikes 41 11-16-2006 10:09 PM
Bad tank of gas minnzoo3 Kawasaki Cruisers 13 09-01-2005 06:37 AM
