Help! Turn signal not working right.
+ Reply to Thread
Results 1 to 14 of 14
Thread: Help! Turn signal not working right.
  1. #1
    Into the Wind Forum Supporter barry5k's Avatar
    Join Date
    Apr 2008
    Location
    Elk Grove, CA
    Posts
    676
    Default Help! Turn signal not working right.
    My right front and back turn signals are blinking quickly and the front right blinker is really dim. I changed the front bulb and everything was working normal -for about a day.
    Any suggestions?
    Thanks for your help. I hate to go to the dealership where I live and would rather do it myself with your help.
    Barry
    2007 Vulcan 900 Classic
    2007 BMW R1200RT
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Uncle Bob's Love Child BTK Expert Ronmac1118's Avatar
    Join Date
    Jul 2007
    Location
    NW GA
    Posts
    284
    sounds as tho you got a bad flasher
  4. #3
    bustedfeet BTK Expert
    Join Date
    Jun 2006
    Posts
    2,661
  5. #4
    Got KZ? BTK Expert LoudFastUgly's Avatar
    Join Date
    Oct 2007
    Location
    Ontario Kanata
    Posts
    934
    clean the bulb socket thoroughly, and check the ground on the right front signal.
    KZ550A4
  6. #5
    Kimberly Dawn 1966 - 2009 BTK Expert Joram's Avatar
    Join Date
    Jun 2008
    Location
    Panama City, Fl
    Posts
    999
    I had a very similar problem with my VN800A.
    Turns out that the previous owner changed the front blinkers and when he wired them in the headlight bucket, he just twisted the ends together and put tape on them.
    I had changed the bulbs out and was looking at replacing the relay for the blinker until I changed my headlight bulb and found the mess he left me.
    As in all things, if you hear hoof beats, don't think zebra first. Check the little things out first.. You might just save yourself some $$
    1995 VN800A
    Just Get a Bigger Hammer !!
    National Vulcan Riders Forum
  7. #6
    Join Date
    Jun 2008
    Location
    DC
    Posts
    6
    I also have a problem with my turn signals...I have an 84 gpz550 and the turn signals do not flash???? The hazard lights flash alright and everything, but the single signals merely stay lit. Also, the front indicator lights are always on (just get brighter when tunr signal is switched on); is this right? Thanks for any help you can offer!
  8. #7
    Navy Vet Search & Rescue BTK Expert StarGate's Avatar
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,892
    NBugs, the front lights are dual filament bulbs and they serve as running lights as well as blinkers. That part is normal. Put a new flasher/relay in for the turn signals.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  9. #8
    Patriot Guardian Extreme Forum Supporter RichLockyer's Avatar
    Join Date
    May 2006
    Location
    Chino, CA
    Posts
    28,016
    Sounds like a loose connection in the headlight bucket on one of the round "tube pins".
    Do you have a light bar on the bike? I had this problem on mine shortly after installing the light bar.
    Rapid flash indicates "low" load... either blown filament or an open circuit.
    - Rich
    2006 1600 Ultra-Classic
    Patriot Guard Rider
  10. #9
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,892
    Quote Originally Posted by RichLockyer View Post
    OK Rich this brings up a question for me. I've had the problem of fast blink with a few vehicles that when attaching a trailer the added draw of the trailer lights caused the blinkers to flash very fast. I always had to install a HD flasher to cure this. Knowing that the relay (old style not the new electronic ver.) work because the contact inside is attached to bi-metal strip that bends as it gets hotter and breaks the contact until it cools down. All of this is because of the amps drawn through that bi-metal strip. Of course it heats and cools pretty fast so you get the blink effect. How are these blinking faster with less draw?
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  11. #10
    Join Date
    May 2006
    Location
    Chino, CA
    Posts
    28,016
    I'm not sure what has changed in modern flasher design, but that's how they've been working for a number of years... it's the "signal out" indication.
    In the old days, a lamp out would usually result in the flasher simply not flashing (not enough load to heat the strip enough to open)... unsafe, since it would leave the motorist with neither a front OR rear flasher on that side.
    Same problem when you go to LED indications, or some add-ons like the Kury RTB, which draws it's supply power from the taillight circuit and the turn signal input is only used to operate the logic circuit.
    I don't know if ALL flashers (from an auto parts store) are like this or not, but it's the way the stock MC flashers all seem to work.
    - Rich
    Patriot Guard Rider
  12. #11
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,892
    OK, I know you still work with electronics and thought you might know. All my electronics training is a bit dated now and I haven't worked in the field since 90 so I don't know how they are doing this.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  13. #12
    Join Date
    May 2006
    Location
    Chino, CA
    Posts
    28,016
    Ya, it's been a while since I tore a flasher open though.
    Surprised the heck out of me when my Toyota p/u lost a lamp and went to a fast flash.
    - Rich
    Patriot Guard Rider
  14. #13
    The Cruising Gunsmith BTK Expert
    Join Date
    Oct 2006
    Location
    California
    Posts
    1,459
    Quote Originally Posted by StarGate View Post
    Less current drawn can mean the metal strip opens slightly but does not move as far away from the contact. And, since it didn't get as hot, it cools faster and closes sooner.
  15. #14
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,892
    Quote Originally Posted by bountyhunter View Post
    That sounds reasonable. Hadn't thought about that as a possibility.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. have to replace turn signal
    By philly0128 in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 08-28-2008, 11:44 AM
  2. Help w/Rear Turn Signal Ground - '73 F11
    By kwright in forum Vintage Motorcyle Info
    Last Post: 08-04-2007, 09:15 PM
  3. turn signal flasher stops working
    By lookoutdriftmik in forum The Mechanics Corner
    Last Post: 05-29-2006, 09:54 AM
  4. Electrical Connection turn signal conversion kit
    By BigJohn in forum Kawasaki Cruisers
    Last Post: 10-15-2005, 12:51 PM
  5. Turn signal failure, can't find the problem!
    By ridenagain in forum Kawasaki Cruisers
    Last Post: 08-24-2005, 12:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
