95 zx7
+ Reply to Thread
Results 1 to 5 of 5
Thread: 95 zx7
  1. #1
    Join Date
    Jul 2008
    Posts
    3
    Default 95 zx7
    Help with electrical i am having starting and headlight problems i turn the key and get no headlight and no crank ideas i have read some from a ron and i will be checking my soleniod but i am wondering about the key switch
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    No Significant Other BTK Expert MFolks's Avatar
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,117
    What is the condition of the battery? Are the battery terminals free of corrosion? Check the ground cable(negative terminal) where it connects to the frame. Remove the fuses one at a time and see if any are blown. Check the positive (red cable) to the starter solenoid and see if it is free of corrosion and is tight.
    These are a few basic steps I do when a bike wont start.
  4. #3
    Join Date
    Jul 2008
    Posts
    3
    thank u for responding i have actually done all of those steps so far i just have been so frustrated and found this sit today. any info on the ignition switch u have would be great like what does the brown wire do and the side stand switch is disconnected is that ok i didnt do it and the bike has run without it but should i connect to 2 wires or keep them separate
  5. #4
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,117
    The next step would be to get shop manual that has a wiring diagram in it. The factory shop manual (FSM) has wiring colors and what goes to where.
    The sidestand switch may have a safety provision so you cannot start the bike with it down. Once again a shop manual is the next thing to get.
  6. #5
    Make Mine Pure BHP Forum Supporter WeBeToyz's Avatar
    Join Date
    Jul 2006
    Location
    Redding, CA
    Posts
    1,174
    Quote Originally Posted by MFolks View Post
    On this model you can start the bike but, with the side stand down, once you put it into gear it dies. Having the switch disconnected is OK, but the circuit still needs to be complete to solve the problem. Connect the leads in the wiring harness where the switch leads join the harness. Should be located about center above the engine, below the tank. I removed my tank to make the process easier.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. ZX7 headlights won't turn on ('95 zx7)
    By a-ron in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 07-24-2008, 07:31 PM
  2. 1997 zx6 motor into a zx7 roller?
    By jar75 in forum Projects and "How To" Write Ups
    Last Post: 12-17-2007, 04:34 PM
  3. 89 zx7 engine swap to 96....possible?????
    By bmonk in forum The Mechanics Corner
    Last Post: 06-19-2006, 10:07 PM
  4. Difference between 91-92 ZX7 and 93-95 zx7 engine
    By MarshalGiles in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 05-15-2005, 11:11 PM
  5. Metzeler M1's or Dunlop 208's on zx7??
    By zx7 in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 06-11-2004, 09:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
