Old 08-06-2008   #1 (permalink)
Troutbum
Troutbum's Avatar
Default Shift Linkage / Transmission will not engage
Hi all - I'm going to start a new thread on this. I just replaced a motor on a 1981 kz550 LTD (the old one threw a rod). The new motor is in, started up, and runs fine. But, I can't drive anywhere because the transmission will not engage. Don't think the transmission is the problem, because it is definitely shifting between 1st and neutral - I can feel that with the foot pedal and the neutral light goes on and off - however, the sprocket / drive chain does not engage when in first gear. It's as if the clutch is in and I can't disengage it.
A few questions - Should the pin that is engaged by the clutch rocker spin while the motor is running? (It's not) Also - that pin does not "bottom out" against anything in the engine - I can push it into the engine with no resistance. Is that right? Does the clutch rocker engage the clutch by stopping that from spinning?
Is this a problem with the shift linkage? Do I need to go in behind the sprocket and see what's going on in there with the connection to the transmission? Or is it a clutch disengagement issue ?
I really appreciate the folks on here - Thanks -
Yenzo
'81 KZ 550 LTD and
A dumb minivan because I've got kids
Troutbum is offline   Reply With Quote
Old 08-06-2008   #2 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
No the rod doesn't spin. Sounds like you have issues with the pressure plate and or it's movement. I would remove the clutch plate cover and see whats going on.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 08-06-2008   #3 (permalink)
LoudFastUgly
Got KZ?
LoudFastUgly's Avatar
Clutch plates like to seize together if unused for some time. open the clutch up and have a look
KZ550A4
LoudFastUgly is offline   Reply With Quote
Old 08-06-2008   #4 (permalink)
Troutbum
Troutbum's Avatar
Thanks - I will open the clutch up tonight.
Yenzo
'81 KZ 550 LTD and
Old 08-12-2008   #5 (permalink)
Troutbum
Troutbum's Avatar
No wonder! (Sheepish Grin) - I took the clutch cover plate off, and there was no clutch assembly. Apparently the shop that sold me the used engine parted out the clutch and forgot about it, or just neglected to tell me about it. So, I'm going to swap out the one from the old engine.
However, I can't get the clutch hub nut off - the clutch wheel spins freely, and I can't seem to stop it sufficiently to allow enough torque to get the nut off. I think I'll have to take it to a shop and have them take it off.
Thanks -
Yenzo
'81 KZ 550 LTD and
Shift drum on a 03' KX85 hairbear65 Kawasaki Motocross and Offroad 7 08-07-2008 02:06 AM
1978 KZ1000, will not shift up. ZackE Vintage Motorcyle Info 12 06-15-2008 10:09 PM
adjusted the shift linkage newb Kawasaki Streetbikes/Sportbikes 3 04-15-2008 01:07 PM
Mule transmission linkage chorizo Kawasaki ATV and Mule 3 01-03-2008 10:41 PM
Meanie shift linkage gepowell11 Kawasaki Cruisers 1 03-26-2006 11:12 AM
