#22 (permalink) |
Navy Vet S.A.R. crew
I agree Jake. Even as easy as it is to connect mine, I won't use it most of the time if I plan on riding it in the next 2-3 days. If I'm pretty sure it's going to be 4+ days or if I've done a lot of start and stop short trips that day, then it goes on the charger.
While it's not the most appealing thing in the world, I ran my quick coupler out from under the seat and used zip ties to fasten it to the frame. This way it's easy access and I don't have to worry that it's going to work it's way back up under the seat. Look right above top middle of the side cover at the bottom edge of the seat. ![]() |
#24 (permalink) |
Patriot Guard Rider
![]() Join Date: Mar 2007
Oh, BTW Cheri, I'm stuck at work and she's dead, otherwise I wouldn't link people away from your thread. Mine's here.....
http://www.kawasakimotorcycle.org/fo...ml#post1270319 |
#25 (permalink) | |
Ahhh Crap
Let me ask this and remember I ride a more "primitive" carb'd 1500 Classic so mine is different in this respect. After turning on the ignition, can the key then be removed like on a HD? If so, is there any chance the switch is sometimes being left in the "on" position? You know, shut off the bike with the kill switch and walk away kinda thing leaving the ignition switch still turned on. When the lightbar was installed was a relay used to provide power to the lamps or was it wired in some direct way? Even though the ignition switch may be getting turned off all the time at the end of every ride, power is still being supplied to the high-tech gauges for the clock and maybe the trip meter. If one of those wires has rubbed through it's insulation just a little, it might be draining the battery without blowing a fuse. The FI bikes have a lot of wiring running though some pretty tight places.
Steve 2003 1500 Classic VROC 11660 RB 139 |
#26 (permalink) | ||||
October MOM 07
![]() Join Date: Apr 2006
Thank you! |
#27 (permalink) | |
October MOM 07
Now if it was anybody else doing it....like ole' NCDave....I might have a problem! |
#28 (permalink) |
12 yrs old at heart!
Did I hear my name mentioned?
![]() Kev.....it might be less hassle to just buy a new one. however, I don't know any reason why it should not charge back up.
NCDave Don't Blame Me, I Voted For The Hot Chick http://www.bikepics.com/members/ncdave |
#30 (permalink) |
October MOM 07
Well, we couldn't find anything wrong or out of place....anything drawing current with the key off, so he took it back to our local mechanic. He said he would pull out the schematic on the bike and told Chaz he "WILL" find the culprit!!! Now it will just be a matter of how many days/weeks it takes him!!!
I'll update on the cause when he finds it!!! |
#31 (permalink) |
Alf not Elf
If Chaz has access to a DC volt-ammeter and knows how to use it he can do some checks of his own. Check the battery voltage bike not running should be 12 or so volts. Next start the bike up and check again if the charging system is doing it's thing voltage at the battery should be 14 to 14.5 volts + or - or so rev the bike up a little. If the above checks out the charging system is OK..Next with the bike not running remove the + terminal from the battery and hook a DC ammeter between the positive termiinal and the wire lead he took off, any kind of amperage reading indicates something is draining the battery. Remove the accessory wiring he installed one item at a time and watch the current draw on the ammeter when it goes to zero fixed...
When arguing with a idiot make sure he isn't... My bike 900 LT Red/Black. |
#33 (permalink) |
Cheri...what's the latest???
#34 (permalink) | |
October MOM 07
Now I am NOT a mechanic, so forgive my "feminine" way of describing things....but he basically told me the same thing, but he said use some wire thing with a light bulb on the end. Since it doesn't get drained all the time, he suggested Chaz use it to check with his battery everyday. If the light bulb stays off with the key off, nothing is drawing extra current and he can go on that day and not worry. If he checks it one day and the light bulb DOES come on, then he knows something is drawing current, and to start disconnecting something one at a time until the light bulb goes out. Make any sense? In the meantime, it is STILL sitting at the mechanic's shop He told Chaz they check it everyday and they are waiting for it to go dead again!!!!!! That could take another month, or just a few days.... ![]() |
#38 (permalink) | |
October MOM 07
We THOUGHT this guy knew what he was doing....but in all honesty, his specialty is GoldWings!!!! Here's where I feel bad Tina.....Chaz is getting impatient, of course, and mentioned getting his bike back. I had the nerve....oh dear....I hate to confess it....but I had the nerve to actually scold him and tell him he needed to sit back and learn patience and let the mechanics find the problem!!! <slaps my own hand> |
#39 (permalink) |
![]() ![]() Join Date: Oct 2004
Battery Tender has separate leads that can be permanently installed and also extensions that can be purchased. We've got em and they work great. Sorry about the problems on your trip.
Hers 2006 HD Deluxe (Nostalgia) Mine 2003 Vulcan 1500 Mean Streak-Traded |
#40 (permalink) | |
Life Begins at 200 mph
How old is the battery on the bike? What year is the bike in general. My buddy had a problem like this and it was the battery going bad, but I would check the charging system first. It may not be able to keep up with charging the battery but charging a little. This would cause the prolonged drainage that you seem to be seeing especially if you have a lot of accesories. Also does the bike happen to have a cigarette lighter type power port on it? If so check to see if anything got inside the cup and fused to the conections to complete the circuit, this would cause a constant draw on the system especially if the power port has constant power availible to it. I seen that happen in a buddy's car before. |
