Old 08-28-2008   #41 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
Originally Posted by billc5 View Post
Battery Tender has separate leads that can be permanently installed and also extensions that can be purchased. We've got em and they work great. Sorry about the problems on your trip.
Thanks for the tip!
CheriAnn is online now   Reply With Quote
Old 08-28-2008   #42 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
Originally Posted by SilverBullet View Post
X2.
How old is the battery on the bike? What year is the bike in general. My buddy had a problem like this and it was the battery going bad, but I would check the charging system first. It may not be able to keep up with charging the battery but charging a little. This would cause the prolonged drainage that you seem to be seeing especially if you have a lot of accesories.
Also does the bike happen to have a cigarette lighter type power port on it? If so check to see if anything got inside the cup and fused to the conections to complete the circuit, this would cause a constant draw on the system especially if the power port has constant power availible to it. I seen that happen in a buddy's car before.
The battery was just replaced recently when this started. He was hoping that would solve the problem, but it didn't
He does happen to have a cigarette lighter type power port!!! I'll pass this information on to him!
Old 08-28-2008   #43 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
Okay, here's a question he wanted to throw out here for the experts
He said the light bar on my 900 was wired directly to my headlight.
However, the light bar for his bike came with a relay. He is wondering if that relay could be bad or causing a short. Could he just run the wire directly to the headlight, like he did with my 900?
Thanks!
Old 08-28-2008   #44 (permalink)
NCDave
Clark Grizwald Trainee
NCDave's Avatar
Cheri, has it tried disconnecting everything and just running it like that for a while to see if it clears up? I take it the shop didn't find any problems, huh?
NCDave
Don't Blame Me, I Voted For The Hot Chick
http://www.bikepics.com/members/ncdave
NCDave is online now   Reply With Quote
Old 08-28-2008   #45 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
No, the shop has not been any help so far
He's calling them today and picking it up after work. You all have given him some excellent suggestions to try on his own!!!
Old 08-28-2008   #46 (permalink)
NCDave
NCDave's Avatar
I'd say the best bet is to disconnect everything that's been added, check things then, and then add them back one at a time. I can't wait for the big smiles when he finally DOES!
NCDave
Old 08-28-2008   #47 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
That's easier said than done!!!! That ALOT to disconnect all at once, and how would he know which of those was the culprit? He would have to ride without all those (some I like for safety, like the brake modulator!) for at least two months to be sure
Old 08-28-2008   #48 (permalink)
A2rider
Banned
A2rider's Avatar
He may have to give up some of those things. They may be overloading his system. A battery can only handle so much, and as somebody said, all it takes is one thing to make the whole bike run down.
A2rider is offline   Reply With Quote
Old 08-28-2008   #49 (permalink)
NCDave
NCDave's Avatar
Just depends on how badly he wants to find the problem. He could disconnect them all, then once he determines it's running ok, start hooking up the safety ones first. yeah, it will take a while, but hopefully he'll figure it all out.
NCDave
Old 08-28-2008   #50 (permalink)
NCDave
NCDave's Avatar
That's true Tina. Has he thought about the wattage pulled by all the various things? Maybe he's just using more than the charging system can keep up with.
NCDave
Old 08-28-2008   #51 (permalink)
Vulcan900
Vee-Too-Kay
Vulcan900's Avatar
You hubby’s Nomad obviously has an electrical problem. A battery tender might help hide the problem, but it will not solve the issue. Unless you plan on not riding for an extended period of time I would not bother with one.
The test light (as suggested earlier) probably will not be able to detect the small amount of current that is causing your problem. Borrow or buy an ammeter. In line is OK but I think a quality clamp-on would work better (but more expensive). A clamp-on measures electrical current running through a wire without having to disconnect anything.
Lift the seat and measure the current through the positive battery wire with the key off. If there is current coming from the battery to the rest of the electrical system something is wrong, and you can proceed with trying to find out what is pulling the juice. If it reads zero then your good to go for the day.
If it reads something other than zero, and you are using a clamp-on then you can clamp it onto the wiring for each of the accessories looking for the stray current. If you are using an inline ammeter you can leave it inline with the battery and disconnect each accessory until the current goes to zero. If the accessories don’t seem to be the problem you can start pulling fuses to help narrow down the problem.
By the way, both of my bikes are 2006. I left my key on in the 2000 last night for at least an hour. I came outside and noticed my light were on… the whole headlight bucket was hot. I turned the key off, then back on and she started right up. The 900 has sat for as long as 3 weeks between rides without any issues. I have also accidentally left the key on in it for a couple of hours and completely killed the battery. I learned that you can not push start a VN900 on flat ground.
2006 VN2000 LT - Fire Breathing Dragon
2006 VN900 Classic - Mellow Kitten
Vulcan900 is offline   Reply With Quote
Old 08-29-2008   #52 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
UPDATE!!!!!
His mechanic finally narrowed down the problem....a bad ECU!!!
Since that's a warranty part, Chaz will have to take it to the Kawi dealer, but at least he knows the problem now!!!
Old 08-30-2008   #53 (permalink)
A2rider
Banned
A2rider's Avatar
Would have never guessed.
Old 08-30-2008   #54 (permalink)
RichLockyer
RichLockyer's Avatar
That's a relief!
- Rich
2006 1600 Classic
Member CORVA, BRC
Patriot Guard Rider
Old 08-30-2008   #55 (permalink)
rbentnail
Formerly a Kaw owner
rbentnail's Avatar
Originally Posted by cbh303 View Post
Just my 2 cents worth but I would not wait until the Winter. The constant up and down will eventually kill the battery.
I had the same problem on a brand new bike, '07 900 Classic. It would be fine for a few days and then it would just one day be dead. It turned out it was an bad ECU. The mech at the shop had to have the Kaw rep ship him a new one. Since then all has been good.
UPDATE!!!!!
DINGDINGDING. We have a winner!!! Johnny, tell cbh what he's won....
Good to hear, Cheri, that the problem has been found. It sure is no fun riding only to expect to be stranded.
Russ
On an foot-draggin' 07 Yamaha FJR
rbentnail is offline   Reply With Quote
Old 08-30-2008   #56 (permalink)
A2rider
Banned
A2rider's Avatar
I still wonder if it didn't have something to do with the excess amount of accessories he has on the bike. ECU's rarely go bad, but his might have been the exception.
Old 08-30-2008   #57 (permalink)
RichLockyer
Nahh... most people with touring-style cruisers have as many or more accessories than he has.
Heated grips, vests, gloves, chaps, GPS, 200w stereo, 100w of aux lighting....
- Rich
2006 1600 Classic
Member CORVA, BRC
Patriot Guard Rider
Old 08-30-2008   #58 (permalink)
A2rider
Banned
A2rider's Avatar
You could be right. My idea of excess accessories are turn signals.
Old 08-30-2008   #59 (permalink)
Classic
Ahhh Crap
Classic's Avatar
Yeah, highest technology on my bike is the self cancelling turn signals. Most of the big Vulcans have major-league electrical systems with the exception of the Mean Streak (I think) so running tons of accessories is no problem as long as it's not an arc welder. The bad ecu must have been staying energized to some extent and drawing down the battery. I'm a little surprised it was intermittent and that they found it so quickly.
Steve
2003 1500 Classic
VROC 11660
RB 139
Classic is offline   Reply With Quote
Old 09-02-2008   #60 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
Tina, I have seen SO MANY MORE accessories on bikes, and although I haven't seen them in person, on the Nomad forum, there are bikes with MEGA bling!!!!!!!
As for the ECU, he talked to Chaz about the details, but along with some testing of components, I THINK he told Chaz he had everything unhooked from the battery except the ECU and the battery was dead the next morning.
When Chaz called our local dealer (who we cringe having to use) and talked to someone in service, he told Chaz they could test the ECU and relays (another possibility according to our local mechanic) and know the cause within an hour We'll see......we're dropping it off today after work.
1500 Nomad vs 1600 Nomad Question nonyab Kawasaki Cruisers 7 07-18-2008 05:48 PM
