Old 08-19-2008   #1 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
Unhappy Dying Nomad
Well, I know that this can't be solved on a forum board, so I am really just venting.....
Hubby's 07 Nomad developed a dead battery problem about 3 or 4 months ago. It's the WORST kind of problem though.....it doesn't happen all the time!!!!!! He can go weeks with it starting up every time, then suddenly one day...BAM, dead battery!!!! It may only go days the next time before going dead. He replaced the battery before the PA Forum trip and thought maybe that solved it, but Sunday morning he went out to start it for work and it was dead. He had our local mechanic (whom we trust very highly) check over his wiring on things he has added himself (light bar, brake light modulator, etc.) and he didn't find any problems with the wiring.
So, here's something that I am wondering....since it doesn't do it all the time it will be hard for a dealer mechanic to pinpoint it, I'm sure. Should we trailer it in during a dead spell and NOT charge it? Could they possibly find the cause like that?
The bike, of course, is still under warranty, but this is the busy season. Hubby said for now he'll recharge and ride until winter sets in. It's just very frustrating
CheriAnn is offline   Reply With Quote
Old 08-19-2008   #2 (permalink)
NCDave
Clark Grizwald Trainee
NCDave's Avatar
Oh yeah....that's the worst. I don't know it taking it in at that point will help or not, but I guess it couldn't hurt. He's right to check the wiring, because a short someplace could be doing it. it could also be the regulator/rectifier, but with being intermittent, I wouldn't think that's bad.
Is there any indication of it going down? Does the bike start sluggish a few days before or anything like that? Or is it just overnight?
He might consider getting some type of volt meter or indicator to put on it to monitor the condition during running.
NCDave
Don't Blame Me, I Voted For The Hot Chick
http://www.bikepics.com/members/ncdave
NCDave is offline   Reply With Quote
Old 08-19-2008   #3 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
DAVE!!!!! What a brilliant idea!!!!
That's why I just LOVE this place!!!! You can rattle off about stuff and somebody will have a suggestion you didn't think of!!! It's usually something simple that we overlook in the midst of frustration
There's NEVER any warning signs ahead of time. He'll just go out, turn the key, and dead! With a volt meter, maybe it would show some fluctuations or something when using certain things, like his light bar.
I called him at work and gave him your suggestion!
THANK YOU!
Old 08-19-2008   #4 (permalink)
NCDave
NCDave's Avatar
What better way to post my 7,000th post than to say.....You're welcome!
NCDave
Old 08-19-2008   #5 (permalink)
Frenchy
Needs A Real Job
Frenchy's Avatar
I had a similar problem on another bike. It turns out the stator (altinator in a bike) had a bare wire that would arc and toast it, making it not charge the battery. It would die on me while riding sometimes though. Sometimes I would just hit the button, and nuttin.
Frenchy
'05 Nomad 1600
AD/HD: Attention Deficit in High Definition
Frenchy is offline   Reply With Quote
Old 08-19-2008   #6 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
YOU POST WH@%&!!!!!!!!!!!
How dare you take this thread to other places!!!!
Just kidding!!!!!
Congratulations!!!! You're growing up to become quite a little young man now
Old 08-19-2008   #7 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
Boy, then you understand the frustration!!!!!
I'm happy you finally got your problem resolved. I'm hoping he can get his resolved eventually..
Old 08-19-2008   #8 (permalink)
A2rider
Banned
A2rider's Avatar
Do what Dave said and check to see if it's charging. If it is, them you've got a drainage problem going on when it's sitting. He may have to check each thing he added to see which one is being the leach. Just because the wiring looks fine, doesn't mean it's not slowly leaching the battery.
A2rider is offline   Reply With Quote
Old 08-19-2008   #9 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
Good idea! Do you mean disconnect something he added one at a time to see if there is a difference? Honestly, we think the problem started after he added the lightbar and brake modulator. Everything is connected correctly (as confirmed by our mechanic) so we didn't think that was the problem. So, I just learned something else new!!!! Thanks Tina!!!! It certainly does appear to have something leaching from it!!!
Old 08-19-2008   #10 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
Not sure how easy it is to disconnect a lead from the battery on that bike, and it would sure be a PITA to do it every time he parked it, but checking for a slight drain while the bike is parked is another possibility. Just disconnect one of the battery leads then connect a volt meter at the battery terminal and the disconnected cable end to see if there is any reading. Are you keeping a trickle charger connected when the bike is parked?
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 08-19-2008   #11 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
Thank you, thank you, thank you!!!!
I am welcoming ALL suggestions!!!! I am printing all this out for him to try!!!!
You all are the best!!!!
Old 08-19-2008   #12 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
Whoops! Forgot to answer this....no. He thought about getting one, but I encouraged him not to until he finds the culprit. He rides the bike alot, so it really doesn't sit for very long at a time in between rides. Maybe 2 days at the most....
Old 08-19-2008   #13 (permalink)
jukief
I miss you, Deron
jukief's Avatar
Cheri, I feel your pain. my battery died while we were on our trip last week. It was a giant PITA because we couldn't push-start it (we tried) and had to have it towed to a Yamaha dealer (the only motorcycle shop in miles and miles). The mechanic there told me that these batteries can really have problems holding a charge, and he recommended keeping a trickle charger on it ALL THE TIME! I've never used one, not even during the winter when the bike can sit in the cold garage without being started for a month at a time. I'm not so sure what I think about his advice, but that darned battery cost me so much that I'm going to take care of it.
In memory of my friend Deron Harden. Life isn't going to be the same without him.
jukief is offline   Reply With Quote
Old 08-19-2008   #14 (permalink)
StarGate
StarGate's Avatar
IMO a trickle charger that has the float function is a great investment to prolong battery life. I use mine any time I park my bike that I'm not sure how long it will be until my next ride. With the quick connect coupler, it only takes me about 5 seconds to hook it up and even less to disconnect it.
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
Old 08-19-2008   #15 (permalink)
skewterdewd
Team Zissou
skewterdewd's Avatar
I would start by testing the modulator circuit again. It's possible that the circuit isn't closing/functioning correctly, causing the battery to draw slowly down.
If the lightbar has a remote thumb switch make sure the contacts are clean secure, and dry. Check the wire termination for strays and breaks.
Don't overlook the obvious- are the battery terminals and ground solid?
These problems blow, but be patient and you will prevail.
skewterdewd is offline   Reply With Quote
Old 08-19-2008   #16 (permalink)
Jake '53
It will do all of the above and then leave you stranded on a 3 day road trip because you didn't find out there was a problem with your charging circuit.
"Certainty of death. Small chance of success. What are we waiting for?" - Gimli
Jake '53 is offline   Reply With Quote
Old 08-19-2008   #17 (permalink)
StarGate
StarGate's Avatar
Not sure what you mean by this and a trickle charger should never be considered as a fix for an electrical problem, whether it be with the charging system, battery, or wiring. It will help you get the maximum life out of your battery and ensure your battery is at peak voltage when you leave on a ride.
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
Old 08-19-2008   #18 (permalink)
Jake '53
I agree that a trickle charger shouldn't be used as a fix, but it can mask high resistance shorts or problems with the charging circuit that might not show up until the battery has been off of the charger for a couple of days worth of riding.
Old 08-19-2008   #19 (permalink)
cbh303
Send a message via AIM to cbh303
Just my 2 cents worth but I would not wait until the Winter. The constant up and down will eventually kill the battery.
I had the same problem on a brand new bike, '07 900 Classic. It would be fine for a few days and then it would just one day be dead. It turned out it was an bad ECU. The mech at the shop had to have the Kaw rep ship him a new one. Since then all has been good.
cbh303 is offline   Reply With Quote
Old 08-19-2008   #20 (permalink)
jukief
I miss you, Deron
jukief's Avatar
That's what I need--a quick connect coupler! It's a PITA to take that seat on and off.
