Old 08-26-2008   #1 (permalink)
agentfox1942
Army Strong. Ride Long
agentfox1942's Avatar
Default Additional Turn signal draw
Does anyone know if I install an auxiliary set of turn signals on my '05 1600 classic will the flasher be strong enough to flash all six lights? The new ones are the small halogen silver bullets. Specs say they draw 4 amps, but I come up with less than 3 with a 30 watt bulb (watts = volts x amps 30/12=2.5)
Thanks
Mark
Hagerstown, MD
'05 Vulcan 1600 Classic
"Chrome don't get you home"
agentfox1942 is offline   Reply With Quote
Old 08-26-2008   #2 (permalink)
MFolks
Way Too Much Free Time
The flash rate may increase if the flasher is stock. The newer electronic ones are supposed to compensate for LED's and regular bulbs. Give it a try,the only thing I think will happen is shorter flasher life with more lamps.
Old 08-26-2008   #3 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
I'd check to make sure the wiring is rated to handle the total new amp load also.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 08-26-2008   #4 (permalink)
agentfox1942
All good points. Thanks
Mark
Hagerstown, MD
Old 08-26-2008   #5 (permalink)
turbochardged
it will change the flashing rate, also check wire load. Add front and rear amps that's your total load on the flasher, if you add a extra light then you have to compensate by replacing one of the original bulbs with a smaller amp bulb to make up the difference. It's ok if your not exact (off by an amp)
turbochardged is offline   Reply With Quote
Old 08-26-2008   #6 (permalink)
RichLockyer
RichLockyer's Avatar
I think they'll be fine.
The stock bulbs are 21w, and the circuit is a 10a circuit.
I believe the circuit also powers the brake light (another 21w), so you have a total of 3 bulbs at 63 watts with front and rear, another 10 watts for the 2 front running lights and another 5 for the taillight brings you to 78 watts.
That'll total 108 watts, which is still only about 7.7 amps (at 14v, not 12)... you're below 80% of the fuse/circuit rating.
I know for a fact that you can run 110 watts off of the 10 amp accessory circuit.
- Rich
2006 1600 Classic
Member CORVA, BRC
Patriot Guard Rider
Old 08-27-2008   #7 (permalink)
agentfox1942
Why is it 14volts and not 12 volts? I know my volt meter shows 14-14.5 volts but the bulb is rated at 12 volts. Do I always use the output voltage instead of the draw?
Mark
Hagerstown, MD
Old 08-27-2008   #8 (permalink)
Alizard
The Cruising Gunsmith
Actually, it will flash slower because the bimetallic strip will get a lot hotter, takes longer to cool and come back to reconnect the current.
It may destroy the stock flasher but I do believe auto stores sell "heavy duty" flashers rated at maybe 5A or more to use with trailers which also require additional turn signal lights to be run by the flasher.
Alizard is offline   Reply With Quote
Old 08-27-2008   #9 (permalink)
Alizard
Good idea. Superbrightleds.com makes "drop in" 3W LED's that replace the 1034/1157 type bulbs and use very little current (but are still bright). Install one of those in a turn signal location. Since the turn signals are in parallel, the stock flasher will operate correctly seeing a load of two standard bulbs and one LED in parallel.
Old 08-27-2008   #10 (permalink)
Alizard
If the bulb's wattage (power draw) is specified for 12V, you use 12V to calculate the load current it draws. FYI, at 14V, the bulb will draw about 16% more current than at 12V.
Watts = Volts x Amps
Amps = Watts / Volts
If the bulb's power (Watts) is specified for 14V, you calculate the current using that voltage.
The wiring and fuses are rated in Amps, they don't care about voltage.
Old 08-27-2008   #11 (permalink)
RichLockyer
I believe the bulbs are rated for 14v, since that is the nominal operating voltage of motor vehicles.
NAPA and Phillips both show their 1157 bulbs as being 12.8/14v... not really clear, but the difference is significant. A 100 watt bulb rated at 12.8v would draw a touch over 109 watts at 14v.
Only way to know for sure would be to put an ammeter on a bulb.
- Rich
2006 1600 Classic
Member CORVA, BRC
Patriot Guard Rider
Old 08-30-2008   #12 (permalink)
Alizard
My FSM says the bulbs are:
12V: 23W/8W (turn signal filament/running light filament)
That would mean at 14V, the Wattage would be: 31W/11W
Old 08-30-2008   #13 (permalink)
RichLockyer
Put an ammeter on it... that's the only way to know for sure.
- Rich
2006 1600 Classic
Member CORVA, BRC
Patriot Guard Rider
Rear Turn Signal Wiring Problem DevilishMeanie Kawasaki Cruisers 4 02-03-2008 02:02 PM
Another Ride to PA Grand Canyon (Fall colors are coming!) dropdfocus Rides, Events and Rallies! 49 10-23-2007 11:18 AM
Ninja 250 front turn signal lense Ridge Rider Kawasaki Streetbikes/Sportbikes 6 10-18-2007 06:17 PM
Location of the Turn Signal Flasher on Vulcan 900LT? Desmond57 Kawasaki Cruisers 8 09-01-2007 09:37 AM
EX500 turn signal switch Daekar The Mechanics Corner 1 07-16-2004 09:50 PM
