Old 09-01-2008   #1 (permalink)
MR.S7
Way Too Much Free Time
MR.S7's Avatar
Send a message via ICQ to MR.S7 Send a message via Yahoo to MR.S7
Arrow Motorcycle scanner?
How good it is? does it worth it?, any one tested?
The passion of motoaction!
MR.S7 is offline   Reply With Quote
Old 09-02-2008   #2 (permalink)
jay08
Foil Inspector
A Motorcycle Scanner MS5650
View More Images Our low price: $3,059.99
Item Number: MS5650
Manufacturer: Motorscan
Manufacturer Part No: MS5650
Quantity:
* Whole number only
Add to a new shopping list
Email this page to a friend
Covers all electronically diagnosable systems including ignition, injection, immobilizer, ABS, instrument panel, and service light reset on motorcycles from all major manufactures, Including Marelli cable (Packard Plug), BMW cable, Harley-Davidson cable, Triumph cable (OBD II plug), universal cable for other manufactures, Battery cable, power supply cable, data router.
ECU automatic and manual research.
ECU data display.
Current and memorized errors (DTC) reading.
Errors memory erasing.
Data display in real time (RPM, battery voltage, throttle angle,..).
Components activation and test (injectors, ignition coils, fuel pump, ecc.).
TPS Zero-setting (throttle valve position sensor).
Injection regulation (CO Trimmer).
Immobilizer unlock.
Switching off of service pilot light.
Includes operation manuals on CD, and heavy duty carrying case.
Product Reviews
Login to rate or review this product
(0 Ratings, 0 Reviews)
This is the one i have seen and it's not cheap 3000.00. Not sure it's really worth it yet. The ABS feature looks nice and you can find a bad coil without pulling the tank also nice .But i bet it's just like an auto scanner it will give a code like missfire number 3 then you have to do the diag and find out why. I could be wrong havent used one yet. Emission systems just started comming into bikes. Thats kinda steep in price for tech to have in his or her box lol maybe one for an entire shop. But yea if anyone has used one i would also like to know how good they are ?
jay08 is offline   Reply With Quote
Old 09-02-2008   #3 (permalink)
RichLockyer
RichLockyer's Avatar
I don't think it's worth the investment at this time.
VERY few bikes have "scannable" ECUs. The bikes listed in the above unit are about it.
I would not consider it a wise investment until new emissions regulations push bikes into something equal to the automotive OBD-III
- Rich
2006 1600 Classic
Member CORVA, BRC
Patriot Guard Rider
Old 09-02-2008   #4 (permalink)
coppertales
Uncle Bob's Love Child
Default Sounds like something...
for new bikes with the computer driven electrics. Absolutely no use to my 82 KZ1100s.....chris3
coppertales is offline   Reply With Quote
Old 09-02-2008   #5 (permalink)
MR.S7
MR.S7's Avatar
Post
wich bikes listed on the above Rich? i thought it would work in any bike with a cdi..
what ecu initials means?
Old 09-02-2008   #6 (permalink)
RichLockyer
The bikes listed in Jay08's post:
ECU is short for Engine Control Unit, or some people call it "Electronic Control Unit"
It's more than JUST the CDI, it's how the software in the ECU is written. My dirtbike has a CDI, but there's no way to even access it for trouble codes.
On the Vulcan cruisers... 900, 1500, 1600, and 2000, you install a diagnostic jumper on a plug under the seat and the ECU flashes the FI light on the instrument panel in a "dot dash" pattern that the tech cross-references to the potential problem.
MOST bikes that have EFI use this type of diagnostic method. Very few have an actual plug-in interface like modern cages do.
Give it another 5 years or so and a device like this might be a good investment for a shop that services a lot of new bikes, but it will never be of any use at all on most bikes built before that time.
- Rich
2006 1600 Classic
Member CORVA, BRC
Patriot Guard Rider
men's rules for women - wouldn't let the wife see Freakinout Off Topic 48 02-26-2008 10:59 AM
local news:Driver of stolen motorcycle ends up in hospital zedx11 Main Lobby 54 11-19-2007 02:34 AM
Looking to tow motorcycle with my sedan. Possible? Lord U Main Lobby 43 09-03-2006 05:13 PM
June 2006 NHTSA motorcycle stats and findings DrunkenMonkey Main Lobby 2 08-14-2006 01:05 AM
Guidance for a passenger rbentnail Main Lobby 6 02-08-2005 07:57 PM
