Old 09-06-2008   #1 (permalink)
Hercegov
Default Tail light goes out when turn signal on.
Hey everyone.
I've tried 2 other forums with little luck so far and though I'd try here as well
I recently bought an 02 ZX7R and had the issue with the fast flashing turn signals even though there was no change on any of the lights and all worked just fine. So I ended up replacing the tail light with an LED one that had built in turn signals because the previous owner removed the rear turn signals as well as the fender.
I did some research and found ( Install electronic constant rate turn signal relay : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums ) I ended up replacing the flasher relay with the Tridon EL12 and it worked just fine.
Two days ago I replaced the stock front turn signals to the flush mount LED ones, once again they work fine, however, whenever I turn on either the right or the left signal my rear tail goes out while the signal is working fine, as soon as I turn off the signal the tail comes back on.
I tried putting the stock relay back on and the problem still exists so it's not the relay.
I hooked up the front turn signals (that I replaced with LED) to the back turn signal wires and the problem went away, signals working and tail light as well.
The rear signals don't have two wires for each signal coming out of it, it has a yellow and a blue wire (positive) for each side, the ground wire is supposedly hooked up to the tail ground. Somehow it's effecting it I just don't know how. The tail light it's self is hooked up with the plug, 3 wires coming to the plug and 3 wires going into the light.
The front LED turn signals do have 2 wires for each signal...
Any ideas?
Hercegov is offline   Reply With Quote
Turn signal mod w/ pics rbentnail Projects and "How To" Write Ups 9 10-03-2007 09:30 AM
Installing Light Bar. Questions about unplugging the turn signals NomadNorm Kawasaki Cruisers 1 10-03-2006 07:02 PM
Corroded Turn Signal? kobender Kawasaki Streetbikes/Sportbikes 0 10-11-2005 03:08 PM
Turn signal failure, can't find the problem! ridenagain Kawasaki Cruisers 5 08-24-2005 01:27 PM
