I have a 2004 Ninja 250, Have nearly 6000 miles on it and have had no problems. I started it up this morning and had no issues, this afternoon I went ot start it up and I turned the key on and all good until I hit the starter switch, then I lost all power. I pulled all the fuses and all were good, a few min later the power came back until I hit the switch again and lost power.
If I let it sit for a bit I get power back, I get lights and all until I do anything, if I pull the brake, turn the brights on, try to start it any differnt load kills all power. Once again all fuses are good and when I try to start it I hear and can feel a click from what I think is the Starter solenoid. ANYONE have any ideas on what to check or how to trouble shoot |
#2 (permalink) | |
Finally Got Into First Gear
Other then that you have a short or your battery is no good and shorting itself out. |
Forensic Bug Splatter Analyst
It's your battery.
Remove you battery and carefully check it for fluid as they can evaporate fluid over time. If it's low, go to Yuasa.com it's a battery website that has tips on battery maintaiance. Check your connections at the battery after you have looked over the battery. If it's low and you need to add some de-ionized water it will need to be charged before being reinstalled. Charge at 2amps/hour overnight. I have had motorcycles for 23 years and have "NEVER" changed a fuse. My money is on a weak battery. Good luck.
1984 Ninja 900 (A1) To make it go faster I need to add more lightness! |
| ninja 250 wiring diagram-CDI | ten | The Mechanics Corner | 6 | 07-12-2008 10:40 PM |
| New 250 Ninja for 2008 *Merged Threads* | xeon | Kawasaki Streetbikes/Sportbikes | 640 | 06-06-2008 09:28 PM |
| Just did Valve Adjustment on Ninja 250 | Plato | The Mechanics Corner | 3 | 12-10-2007 12:51 AM |
| 2006 zx10r 06 250 ninja, gsxr 600 parts for sale | alfieferenzo84 | Streetbikes Buy/Sell/Trade | 0 | 08-19-2007 03:48 AM |
| I cant decide Between a 1991GPZ500 and a 1992 Ninja 250 | TeleNinja | Kawasaki Streetbikes/Sportbikes | 8 | 02-02-2006 10:47 AM |
