#41 (permalink) |
It doesn't really seem like anyone is answering your original question. That of course is because no one knows what it is. From what i can tell it's the vacuum valve or "diaphram" or possibly a wheel bearing. If it's a wheel bearing then no, you can't fix an enclosed bearing, but they also are not that expensive so that's probably not what it is. I had 2 holes in my diaphram a few months ago and patched them very carefully with a high temperature epoxy. So far it's worked very well. Maybe that will help, but maybe not.
#42 (permalink) | |
Way Too Much Free Time
I just thing Half dont really ever opened a carb from that side, and the other half is just having fun with the "amigo".. =/
The passion of motoaction! |
#43 (permalink) | |
preciseley what i said.
#44 (permalink) | |
thats why the owner is now here hes got tired of the bad work of the last shop.. I can tell they made a big damage to the bike.
#45 (permalink) |
Oh you should seen my other posts.. at the end always turn in a diferent topic of what i posted.
I remember once i posted about having a good passenger but i guess i used a bad translation so i wrote "hye guys whats the best position wiht your girl" OMG it ended with pictures of my ex! some how!
#46 (permalink) |
SO.. .
Heres a place that REbuild diaphragms , mostly for cars, they told me they can make a new ones, but the material they use seems more rought is nt thin like the OEM, do you think it might affect the performance??
#47 (permalink) | |
Navy Vet S.A.R. crew
Ask them about the flexibility of the one they would make compared to the original material. If it's too stiff it would definitely cause problems. |
#48 (permalink) | |
they look flexible, its just they are not thin they are more heavy rubber u know?.. would the weight affect it?
#49 (permalink) |
I don't think weight would be a problem as long as the flexibility was about the same it should work. Thats assuming the thickness of the new material didn't cause a problem with the cap fitting or something like that.
#50 (permalink) |
Insect Impact Analyst
![]() Join Date: Mar 2008
The flexibility is going to be a big issue. The diaphrams on most car carbs is used to simply pull the choke or some other mechanism open under vacuum. They are either full open or full closed for the most part. The slider diaphrams have to meter the fuel, so if it is too stiff, they are not going to open up enough and the engine is not going to get the right fuel mixture for a certain condition. The same thing will happen if they are too thin. They will open up too far and cause problems. That is one of the reasons that they are so expensive.
You could try and cross reference the carbs on that bike and see what other models use the same ones. Then you could scour ebay for those models as well. I do not know what models have the same ones, but maybe someone on here does. Or maybe a dealer could help you find that info? |
| How to fix FI light. | pqbrown | Kawasaki Streetbikes/Sportbikes | 5 | 04-11-2008 12:21 AM |
| You just can't fix stupid | BigJohn | Off Topic | 20 | 07-28-2007 05:23 PM |
| Quick fix for rough running engines | Bucko | Vintage Motorcyle Info | 0 | 05-18-2007 09:37 PM |
| I can fix my own bike | GreenJello | What I learned today | 9 | 11-15-2006 01:59 PM |
| Election Day Antics - How much $$ to fix throttle handle? | aaronechang | The Mechanics Corner | 2 | 11-03-2004 04:44 AM |
