Way Too Much Free Time
![]() cause its terribly expensive, the four of them are broken like that.. is there ANy way to fix that? or new one is the way? ps: if any one has them i can buy them urg. its form a zx600e 1993 thanks guys
The passion of motoaction! |
Clark Grizwald Trainee
The picture isn't clear. I can't even tell what it is.
NCDave Don't Blame Me, I Voted For The Hot Chick http://www.bikepics.com/members/ncdave |
m m im pretty sure if you knew the answer certainly you would already knew whats the problem with that picture, doesnt need to be more clear than that for the knower.
its a valve vacuum with a hole.
#5 (permalink) |
Looks like a perished diaphragm from a CV carb, don't know if you'll manage to glue or repair it well enough for it to maintain either the vacuum it needs to work properly or without affecting the smooth rise and fall necessary for correct fuel metering at part throttle by the needle.
#12 (permalink) |
here a link more clear: Pictorial TK carb Main jet, needle spacing change - Yamaha TW200 Trailway Discussion Forum
#13 (permalink) | |
Forensic Bug Splatter Analyst
Whoa whoa there amigo! I've been around bikes for 35 years and while I may not be an expert, I, like many here cannot always tell what part of a bike your picture is from. It looks like a rear axel bearing. It looks like the inner housing for the alternator. It looks like a side cover for some bike. It looks like a horn diaphram. Cover for oil filters. Gasket assy for headlamp . Airbox boot for carburator. Anyways, have fun with your carb. overhaul.
1984 Ninja 900 (A1) To make it go faster I need to add more lightness! |
#14 (permalink) |
It's the vacuum slide inside the carb. it's got a diaphram on the end of it. That's the one that was bad on my Vulcan when it was only running on one cylinder. He has one for each carb, I'm assuming.
S7, I don't know of any way to repair the rubber gasket. I'm guessing that's what is torn in the picture, correct? Your best bet is to buy a new one, but you could also check on the internet for used motorcycle parts and perhaps you can located a good used one. Not sure about shipping to your country though.
#15 (permalink) |
Can't find time to ride
Not cheap for a repair either!! $175 US Dollars Carburetor Diaphragm Repair
Try this method for $6 !! XS11.com - Carb Diaphragm Repair Try these guys in the UK. NRP motorcycke carburettor repair specialist That's enough for now, got to go riding on this beautiful day.
Kent Oklahoma City, OK '78 KZ 650 B2 '83 KZ 750 LTD F1 Shaft |
#16 (permalink) |
Dazed and Confused
![]() ![]() Join Date: Feb 2008
It looks like it was a Jelly donut, that got overcooked....easy to solve.
Make a new batch, and cook less time, they should be brown not black. ![]()
Riding is good for ones soul. Riding amongst friends is even better. |
#17 (permalink) | |
Good luck. |
#18 (permalink) |
AZ's Official Mechanic
dam its not that hard to tell its a diaphram.
personally i would try super glueing them to see if they will hold/work first before buying 4 new ones. or get a set of old carbs off ebay. |
#19 (permalink) | |
A lot of your posts are difficult to work through because you use different terms than we do for various parts... such as this one. "Valve vacuum" is probably a literal translation that actually should be phrased as "vacuum valve"... but as someone else mentioned, we call it a diaphragm. The diaphragm is a PART of what we would refer to as the valve. In "valve", we would normally be referring to the complete assembly with the actuator rod, cover, etc...
- Rich 2006 1600 Classic Member CORVA, BRC Patriot Guard Rider |
#20 (permalink) | |
The only thing that I can think of that MIGHT work is Aquaseal. It's a glue similar to Shoo Goo or RTV, but it is VERY sticky, and it flows out very well. I actually use it to seal holes from stitching in my scuba drysuit. But I don't know if it's available in Ecuador.
| How to fix FI light. | pqbrown | Kawasaki Streetbikes/Sportbikes | 5 | 04-11-2008 12:21 AM |
