Old 09-27-2008   #1 (permalink)
theopowers
theopowers's Avatar
Default air hose material?
Looking to buy some longer hoses for my compressor. Why would I choose rubber over pvc or vice-versa?
theopowers is offline   Reply With Quote
Old 09-27-2008   #2 (permalink)
Ole Yeller
Ole Yeller's Avatar
Well, my compressor came with one of those yellow plastic coiled lines and the thing was always getting tangled up with itself so I switched to an old fashioned rubber hose that for me is easier to work with.
4 cylinders are better than 2
1985 ZL900 ELIMINATOR
Ole Yeller is offline   Reply With Quote
Old 09-27-2008   #3 (permalink)
MFolks
Wants better weather!
PVC is like a bomb waiting to go off! Most air compressors are oil lubricated and this will degrade the PVC line to the point of bursting and throwing sharp bits all over! The safe way to go would be rubber hose or thick walled copper pipe if this will be a permanate set up.
Don't forget when plumbing the lines to allow condensation to flow to drain valves. The website www.practicalmachinist.com/vb/forumdisplay has covered this matter and I believe a plumbing diagram is in the files.
Old 09-27-2008   #4 (permalink)
Saleenguy
Dazed and Confused
Saleenguy's Avatar
I prefer the heavy duty, rubber hose on my compressor.
It stays flexible, does not kink, and has lasted many years without failure.
The cheapy plastic crap hoses suck, and should be burned.
Riding is good for ones soul.
Riding amongst friends is even better.
Saleenguy is offline   Reply With Quote
Old 09-27-2008   #5 (permalink)
Redbeard
Redbeard's Avatar
Ease of handling in cold weather. Some of us don't have heated garages.
Redbeard
2006 1600 classic
Patriot Guard Rider #5776
Life ain't easy when your Fat and Greasy
Redbeard is offline   Reply With Quote
Old 09-27-2008   #6 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
the PVC hoses are CRAP CRAP CRAP and dont like to lay flat when ya uncoil them. i switched to black rubber and they are awesome. all from harbor freight to be exact.
QKENUF4U is offline   Reply With Quote
Old 09-28-2008   #7 (permalink)
jbsmd
nu2kawi
jbsmd's Avatar
Corded rubber last longer and will handle more pressure. Plastic lines are just cheap, but will hold pressure from a small compressor and kink easy.
07, Z1000
01, XVS1100LC Yam cust.
jbsmd is offline   Reply With Quote
Old 09-28-2008   #8 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
I have a 100' polyurethane (poly) air hose that I have been using for about 15 years now. It doesn't get dry rot cracks like I had with rubber and it gets very heavy use (daily in most cases) with my nail guns and other air tools on a regular basis. It's rated for 250 psi and will remain flexible and easy to coil in the coldest of temps. I'll never use rubber or plastic again and if this one ever wears out I'll definitely buy another one just like it. I can't even count the number of times I've had this hose run across the concrete driveway on a job, and driven over it with my truck and it's still like new as far as I can tell. Great stuff.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 09-28-2008   #9 (permalink)
jeffs99vulcan
On a steel horse I ride
jeffs99vulcan's Avatar
Just don't cheap out... rubber (or poly as above) will stay flexible, PVC will not. Flexibility (lack of it) will become your number one headache if you get a stiff, brittle hose...
If the illusion is real,
Let them give you a ride...
Jeff - Ottawa, Ontario
'99 Vulcan 800 Classic
jeffs99vulcan is online now   Reply With Quote
Old 09-28-2008   #10 (permalink)
bretsk2500
'07 ZZR600
bretsk2500's Avatar
Send a message via Yahoo to bretsk2500
The only problem I've ever had with rubber hoses in a work environment is they invariably get 1' shorter about once a year as the jacket splits just after where the fittings are crimped on. These hoses see everything, from air nailers on a construction site to my impact guns fixing/maintaining the caterpillar...
'07 ZZR600 Fire Red
11.957@117
Jardine RT1
Factory Pro +4 rotor
Renthal +2
bretsk2500 is offline   Reply With Quote
Constrictor's Caddman Air Mod Tutorial (56k Warning) Constrictor Projects and "How To" Write Ups 233 4 Weeks Ago 11:16 PM
Replacing bars and pipes. alstensby Off Topic 11 03-17-2008 09:43 AM
Thunder Odessy Air Intake Upgrade dalat001 Projects and "How To" Write Ups 1 06-21-2007 04:12 PM
Thunder Odessy Air Intake Upgrade dalat001 The Mechanics Corner 3 04-06-2007 01:07 PM
