Old 09-27-2008   #1 (permalink)
mountainbiker
Default KZ1000 Backfires & won't stay started?
Let me start by saying thanks to all. I have really enjoyed reading your post. I am new to the board I hope to help some one else out like I hope I get help here. So thanks in advance!
The Bike:
1986 kz1000 police bike, former Denver police bike.
The Story:
Was bought by a guy from a police auction about 15 years ago. He owned about 150 of them, and parked this one in his warehouse from the day he got it to the day I bought it. Never even started it. When I bought it about 3 years ago he cleaned the carbs, put a few new plugs in it, fresh gas, go it running remarkably enough in about 30 minutes. I rode it home! Then it got to sit for another 3 years. I did start it every once in a while but nothing significantly enough to make a difference to keep it running smooth.
Recent events:
I had the bike started ran rough but was running. Then I changed the oil, cleaned out the gas tank. Today I pulled the carb, cleaned that. Put it back together.
What it is doing:
Now I half way have it running. The problem is, when it is running I have to hold the gas on about 1500 to 2K RPM to keep it running. Now it seems to back fire a lot as well? I am not sure what to do. I am mechanically inclined, more so on 4 wheels.
Please help me figure out what to do to get it running so I can ride the damn thing! It has been sitting for too long and I have moved it with me 2 times across the country. My girl friend is just about ready to sell it when I am not looking. At least if I get it running I can ride it to work a few nice days a week.
Thanks for all your help.
Rick in ID.
mountainbiker is offline   Reply With Quote
Old 09-27-2008   #2 (permalink)
MFolks
Way Too Much Free Time
Check the voltage at the small wires going to the coils. This should be the same as battery voltage (with the engine off) if it is less than battery voltage then you have a problem with the aged wiring.
A website wiredgeorge motorcycle carburetors - Vintage Japanese Motorcycle Carburetor Sales, Rebuilding and Restoration - Home covers a modification using a relay bypassing the wiring. His website lists parts and wiring diagrams. Many riders at KZrider.com - Home have done this mod with results that make their bikes run better than new. Give his website a look over and make your choice.
Old 09-27-2008   #3 (permalink)
elr658
Motorcycling's Dr. House
elr658's Avatar
First, clean the pilot jets.
1982 Kawasaki KZ1000R1 #658
1980 Kawasaki KZ750H1 LTD
www.myspace.com/79cb750f
Old 09-28-2008   #4 (permalink)
Nessism
Third Gear And Gaining
...and while you are at it, clean the entire carbs and replace the old rubber o-rings. Dropping the floatbowls and spraying out the crud is not good enough.
Nessism is offline   Reply With Quote
Old 09-28-2008   #5 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
And if the above suggestions don't fix it, check to see if you have air leaks around the rubber connectors on both ends of the carbs but I think the pilot jet cleaning will do it.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 09-28-2008   #6 (permalink)
mountainbiker
Default Humm.....
Ok, where do I find the pilot jets?
I hate to ask but I do not have a manual and no money to buy one right now.
Thanks again.
Old 09-28-2008   #7 (permalink)
StarGate
StarGate's Avatar
I believe that bike has the BS34 carbs. If it does, remove the bowl and with the carb inverted, look just forward of the main jet (large brass jet in the middle) and you will see a small aluminum plug about the size of a #2 pencil eraser. Grip it with a pair of pliers/fingers or whatever and pull it straight up and out. The pilot jet is just below it, and be sure to use the proper size screwdriver to remove it. Also check the o-rings around those little plugs and clean the passages below the pilot jets as well.
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
92 ninja 600R carb won't stay connected? ctdubbin Kawasaki Streetbikes/Sportbikes 7 08-09-2008 11:00 PM
Custom 1978 KZ1000, restored to like new! pspmotorman Offroad Buy/Sell/Trade 3 06-18-2008 01:14 PM
KZ1000 Frustrated Norseman10 Vintage Motorcyle Info 3 04-19-2007 10:55 PM
93 EX500 wont stay running runningrasta800 Kawasaki Streetbikes/Sportbikes 17 09-12-2006 02:46 AM
Why do PM's stay in my outbox? ZX6RRNewbie How can we improve? 2 11-25-2004 11:30 AM
