Confused
I have a 95 ex500 24000 miles the timing chain seems to be excessively noisy, is this common on this motor. I have spent 2 years putting this bike together and about 3 weeks all together riding, the last time I thought I was finished it would run for about 10 miles then die I would have to pull off the side of the road pull the choke and try to restart. think the fuel filter was sucking air(didnt have a fuel filter in it when I got it so I added one, hope adding the filter is not causing an issue.)
Speedbump413 |
Needs A Real Job
Remove filter. The one in the tank is doing a fine job.
Rebuild fueltap. Diaphram is sticking with age cutting off the flow of fuel is a possibility. Nylon guides for timing chain worn out? Does ape make a manual adjuster for your bike? ape.com
1984 Ninja 900 (A1) To make it go faster I need to add more lightness! |
| 400 Bayou timing chain | Vargafarm | Kawasaki ATV and Mule | 6 | 08-25-2008 09:36 PM |
| Diagnosing clattering timing chain | jeffs99vulcan | Kawasaki Cruisers | 30 | 08-07-2008 08:06 AM |
| manufacturers suggested!!! | daemon | What I learned today | 25 | 05-12-2008 09:24 PM |
| the chain thread | zedx11 | The Mechanics Corner | 5 | 05-11-2007 10:23 PM |
| Z1-900 Timing Chain Connecting Link? Tuning Info? | bstanz1 | The Mechanics Corner | 2 | 01-09-2004 07:10 PM |
