Old 03-19-2004   #1 (permalink)
hiway_dominator
Send a message via Yahoo to hiway_dominator
Default 1500 Classic Ignition Trouble
I was having trouble with my carbureted 1500 Classic not starting up after
the bike was rode for a little while and warmed up. It would not fire on any
of the plugs until I let the bike cool down for about 15-30 minutes. I
suspected that it had to be the Black box that sent the pulse to the coils.
Kawasaki wanted 360.00 for a stock replacement. I found that Dynatek offered an upgrade (Dyna3000) that 'supposedly' fit right into place and used the stock pickup coils, hi-voltage coils and wire. It would do this for 249.00. I thought great...this is a no-brainer. I ordered it and installed it and the dang thing cranked on the very first revolution of the crank. It idled ok but a little rough. The problem occurs just off of idle either rolling the throttle on or a quick BLIP of the throttle. What happens is that when this is done, it backFIRES thru the carburetor.
(i currently have a 46 pilot and 170 main jet installed)
If you can get it past that point it will run like a bat outta the fiery pits.
I have tried everything from getting a replacemnt from Dynatek to fidgetting with the mixture screw, increasing the pilot jet size (and main jet). The same result. The plugs readings are all ok.
I took the bike to the closest bike repair shop (which happens to be a
Harley shop) and they kept it for a few days. The 'certified' mechanic
called me back and said that it was running fine...that the only thing he
seen was it went dead when he stopped and he increased the idle.
This actually raised the idle above the rev area that caused the trouble. In
other words I am at the same point I was before, because I cant ride this
thing around while it is idling at 1/4 throttle. I'm not a pro, but I wasn't
born yesterday either.
I called Dynatek's support # again and the fellow said that it appears to be
running lean in the low end of the mixture process. The bike ran fine with the original box in place before rejetting for this new UPGRADE. I tried the suspected bad stock box and it wont fire at all now.
I now have it at a Kawasaki dealers Service Dept. It doesn't look like they are going to be able to find trouble either.
If I had a known good stock ignition box, I could tell that maybe the Dynatek isnt working right.
Anybody got any helpful advice? I am going CRAZY !!!!!
Ron Pass
'00 Vulcan 1500 Classic
hiway_dominator is offline   Reply With Quote
Old 03-19-2004   #2 (permalink)
bikeaholic
Sick & Twisted Moderator
bikeaholic's Avatar
Send a message via AIM to bikeaholic Send a message via Yahoo to bikeaholic
Default re
hmmmm- i guess you have already checked for vacum leaks(pinched hose)
idle to just off idle is mostly air/fuel and pilot jet contolled -off the top of my head it just sounds like a tuning problem and sometimes that is a real bastage
i would lean more towards a carb problem than the dynatek
i'll ask around and see if i can find anybody that has had this problem
2004 - 1600 classic
1997 - 1200C harley sporty
1985 - 750 Honda Shadow
VROC# 20171
Chromaholic #512
bikeaholic is offline   Reply With Quote
Old 03-19-2004   #3 (permalink)
hiway_dominator
Default 1500 classic ignition trouble
Thanks. I and 2 shops have played with jetting. I wish I had a known working ignition unit that I could try back in there. I have been told by 2 company' tech support that it could be the pickup coils. this would make sense if I had the trouble across the range of the throttle.
I just dont know. I used to like to do my own work on this thing, but this is driving me nuts. Thanks for your help.
Ron Pass
Vulcan Classic 1500 bigger rear tire! Kenny Kawasaki Cruisers 14 07-23-2008 03:47 PM
COBRA Freeway Bars for 1500 Vulcan Classic kaw4me Accessory Swap Meet 0 10-27-2005 03:57 PM
MUSTANG Studded Seat for Vulcan 1500 Classic kaw4me Accessory Swap Meet 0 10-27-2005 03:43 PM
1500 Classic vs. 1600 Classic Azleite Kawasaki Cruisers 28 08-31-2005 12:46 AM
Handling differences between 1500 Classic Fi and Carb models Mark Williams Kawasaki Cruisers 1 04-29-2004 11:13 AM
