teh GPZ guy
so I am not making the power i was 2 days ago. after pulling and cleaning the carbs i noticed the float bowls have deposits of a rusty looking powder. So i know i need to clean my tank and I know to use a parts cleaner and some washers, my question do i need to remove the pet **** or fuel floaters to avoid damage to the hardware within the tank?
Navy Vet S.A.R. crew
Don't forget to take out the fuel gauge sending unit. I wish you the best of luck but when mine did that I cleaned it and 2 months later I was seeing the rusty powder in the float bowls again. I finally gave up trying to clean it and used a POR 15 liner kit on it.
#4 (permalink) |
did the por 15 work well for you? I have heard thar after a few months or year that the coating breaks down and then you have plastic trash in your tank. I am not 100% sure about this paticular application but i assume it is a form of tank liner
#6 (permalink) |
I put the POR 15 in mine early this past spring. It's held up and preformed flawlessly so far. The liner that is poured in after the cleaning and etching stages looks like a slivery/grey colored paint thats got a high concentration of metallic in it. I'm not sure what it actually is but it doesn't smell like paint. I've heard the same thing about Kreem liners but I've also heard reports that this is caused if you don't allow ample curing time.
| 1600 Nomad gas tank capacity? | RobertNomad16 | Kawasaki Touring and Sport Touring | 42 | 09-24-2008 01:10 AM |
| The final word on internal gas tank rust? | AndrewWoodard | The Mechanics Corner | 6 | 07-24-2008 10:17 AM |
| Gas leak from the gas cap left brownish stuff on the tank | sqldosa | Kawasaki Cruisers | 6 | 06-19-2007 10:30 PM |
| MS Engine sputters after new tank of gas | uf-engineer | Kawasaki Cruisers | 5 | 07-04-2006 02:13 PM |
| Can I use a different gas tank (non CA spec) on my 500 | danielboland | Kawasaki Streetbikes/Sportbikes | 4 | 11-01-2004 04:56 PM |
