Old 10-06-2008   #1 (permalink)
Musgofasa
'08 ZX10R
Musgofasa's Avatar
Default Throttle "Play" on 08 ZX10R
I noticed that my 10r seems to have a lot of loose play. I have to turn it a good 30 degrees before it even starts to move. My last ZX7 was not like this and none of the hondas I have ridden seemed to have this issue. If I recall correctly, my buddy's R6 seems to have a little bit of play, but I don't think it is nearly as bad as mine.
Any ideas on correcting this? I would prefer the throttle to open when I turn the stick instead of after my wrist is bent lol.
Thanks,
Robert
Do not operate in closed in spaces or on small islands
Musgofasa is offline   Reply With Quote
Old 10-06-2008   #2 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
Adjust the slack out of the cable. I always try to imagine the end of the grip has a clock hand pointed straight up (12:00) and adjust the slack so that free travel ends at 11:00. Never take out all of the free travel and that applies to the return cable as well.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 10-06-2008   #3 (permalink)
MFolks
Wants better weather!
Good answer, as if all the play was taken out and you turn the bars the engine speed would go up and you might crash!
Mike Folks
Old 10-06-2008   #4 (permalink)
WeBeToyz
Make Mine Pure BHP
WeBeToyz's Avatar
Send a message via AIM to WeBeToyz Send a message via MSN to WeBeToyz Send a message via Yahoo to WeBeToyz
+1 ^^ - agree - most cables have an adjustment at the carb end as well. Adjust this end to take up most of the slack, and then fine tune it with the adjustment at the control housing.
Bryan
'94 ZX-7
'06 Dragon Run
WeBeToyz is offline   Reply With Quote
Old 10-06-2008   #5 (permalink)
Musgofasa
'08 ZX10R
Musgofasa's Avatar
That's what I was thinking. I didn't want to go to the carb end adjustment if I could do it at the control housing. The adjustment up top is just a knob to turn, the one at the carbs will be a lot of dissasembly.
Not much of a mechanic, but I am willing to play with adjustments so long as I don't think I will screw anything up. I might play with it when I get home and see if I can get it how I want it. Same with the clutch at this point. It is engaging a little farther out than I would like. I know how to adjust that one, but haven't gotten around to it. Tonight might be the night! lol
Take care,
Robert
New Grips... when pull the throttle all the way... it doesnt stop FL Vulcan Rider Kawasaki Cruisers 8 07-09-2008 05:50 PM
good write up for wheelies Army_of_Ninja Kawasaki Streetbikes/Sportbikes 11 05-06-2008 12:37 PM
NNNNNEEEEWWWBBBIII!!! with small probs Shaft Kawasaki Streetbikes/Sportbikes 19 04-30-2007 05:51 PM
A Few Words About Learning To Wheelie X E Ryder Kawasaki Streetbikes/Sportbikes 49 11-01-2006 01:14 PM
