Old 10-13-2008   #1 (permalink)
jose.garcia
jose.garcia's Avatar
Default problem with kz1000-p
i recently bought this beautiful kz1000-p and as soon as i got it went straight to the mechanic to work on the tune up and cleaning and rejetting the carbs cause it was sitting for some time (less than a year) well everything's done but the bike revs up bu itself when i'm ridding it or if i touch ever so slightly the throttle what could this be? also if someone could direct me to a wiring diagram of that bike i'd appreciate it.
thnx
jose.garcia is offline   Reply With Quote
Old 10-13-2008   #2 (permalink)
MFolks
Way Too Much Free Time
Probably a lean condition due to cracks in the rubber intake tubes/hoses either to the carbs or at the point where the carbs attach to the engine.
Get some spray on carb cleaner and spray around the hoses/tubes, if the rpm goes up you have found the crack.
Also remove the small cover on the right side(about the size of a CD and inspect the mechanical ignition advancer. It should change the ignition timing from retard to advanced as the rpm changes. The moving parts need a light oil on the moving parts,springs, and pivots to work properly.
Mike Folks
Old 10-13-2008   #3 (permalink)
jose.garcia
thnx mike i will check that out. Now just in case that's the problem where can i find those rubber boots for the carbs to replace?
Old 10-13-2008   #5 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
Year/model info might help if anyone is going to be able to help with a link to new boots or wiring info.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 10-13-2008   #6 (permalink)
jose.garcia
1994 kz1000p
i appologize i was under the impression that i mentioned that
Old 10-13-2008   #7 (permalink)
jose.garcia
thnxs mike
Old 10-13-2008   #8 (permalink)
StarGate
StarGate's Avatar
The airbox rubbers and manifolds for my 81 are still an active part and available through Kawasaki. I think all the 1000 P's use the same one as mine from 82-05 model. There are no Kaw dealers withing 35 miles of me so I ordered mine online from Z1enterprises.
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
Old 10-13-2008   #9 (permalink)
jose.garcia
can i do a quick fix for now with some high temp silicone?
Old 10-13-2008   #10 (permalink)
StarGate
StarGate's Avatar
Thats very risky at best. Silicone doesn't burn well and an engine that ingest it will not be a happy camper. If it's on the intake area there will be a constant vacuum on it trying to pull it in. If it's just a hairline crack you might get away with it but be sure you clean the surface good before you apply it.
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
Old 10-14-2008   #11 (permalink)
jose.garcia
hey if i remove the baffles on my bike do i have to rejet the carbs?
Old 10-14-2008   #12 (permalink)
StarGate
StarGate's Avatar
It may run leaner but it probably wouldn't require re jet. The bike needs a certain amount of back pressure on the exhaust in order to run right. Just gutting the pipes will make it louder but you may not like the like the way it runs after you are done.
P.S. a replacement exhaust system in good shape from ebay will probably run you around $150-$200 and it's hard to undo what you've done when you gut one. IMO If you want it louder and a little performance boost, look into buying a 4-1 for it.
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
Old 10-15-2008   #13 (permalink)
jose.garcia
cool thanx by the way check out the bike after rewiring and adding led's
ZX7 Headlight Problem green ninja The Mechanics Corner 17 10-28-2008 01:11 AM
VN900 2007 model Stalling Problem Kawa 900 Kawasaki Cruisers 8 03-17-2008 06:02 AM
frustrating problem iracekx Kawasaki Motocross and Offroad 12 09-28-2007 07:07 PM
Problem that has me puzzled iracekx Kawasaki Motocross and Offroad 10 08-21-2007 05:17 PM
2006 EX250 Over reving problem Dave'sEX250F6F The Mechanics Corner 6 03-06-2006 08:52 PM
