Old 10-13-2008   #1 (permalink)
Rob277
Default '80 LTD440 Starter Problem
Hi, Just bought my first kawasaki today. It's a 1980 LTD 440. Got it from a woman who needed cash to make bail for her husband. $300
The bike has been ridden pretty regularly recently as the back tire is almost worn out with no sign of dry rot. The woman told me that she believes that the problem with it was the starter solenoid as her husband had a new one to go on it. I replaced the solenoid but it still won't turn the engine over. It will turn over a little every now and then so i know the engine isn't seized or anything. The starter seems to have trouble turning. It squeals some like a bushing or bearing is worn almost like a car alternator when it's about to go out. The starter also has the cover off of it and what looks like some hammer marks where someone has tapped it to get it to turn.
Does anyone have any input or tips on this? Any would be appreciated as it's been a while since i've worked on a bike and i've never worked on a kawasaki. If I get time tomorrow I plan to remove the starter and have it checked out at a local shop. I'll post a pic of the bike. I think I did pretty good for $300.
Rob277 is offline   Reply With Quote
Old 10-13-2008   #2 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
Nice bike for the price. If it turns out the starter is ok then I'd suspect the squeel comming from the starter clutch but it's probably the starter as long as your sure the battery is good.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 10-13-2008   #3 (permalink)
xcgates
Sounds simple, but once after my bike wouldn't start for some stupid reason or other, I just needed a quick jump, and it worked just fine. And it sounded like the starter or starter clutch was on its way out. Just an idea to eliminate the battery as a problem.
xcgates is offline   Reply With Quote
Old 10-13-2008   #4 (permalink)
TwinStarBMC
Send a message via ICQ to TwinStarBMC Send a message via AIM to TwinStarBMC Send a message via Yahoo to TwinStarBMC
If it worked with a jump, then maybe the battery's weak? It has enough juice to sound like it's trying to start, but not enough to actually kick it over? Just a guess.
TwinStarBMC is offline   Reply With Quote
Old 10-13-2008   #5 (permalink)
Rob277
bike came with a brand new napa battery. which is holding a charge quite well. We did try jumping it just in case but that didn't help.
Old 10-13-2008   #6 (permalink)
Rob277
Just got back to the bike and decided to try a roll it over manually to make sure the basic internals are good. seeems to turn easy enough and good compression. Did notice in the process the starter seems to whine like it's hung up when i roll it. So i'm thinking maybe the clutch is hanging on the starter? Just gotta wait for some shade because it is hot as hell in the sun today.
Old 10-13-2008   #7 (permalink)
MFolks
Wants better weather!
Like most 4 cylinder Kawasaki's the starter is on the left side with the over running clutch for the starting system behind the alternator rotor. The brushes for the starter may be worn down or the bushings for the motor may also be worn causing it to hang up.
A new side cover gasket will be needed as the old ones will tear on removal.
Lean the bike to the right to limit oil loss and carefully remove the left side engine cover to access the starting system. A large soft blow hammer works well for stubborn covers.
Mike Folks
Old 10-13-2008   #8 (permalink)
Rob277
Ok just got the starter off. Hooked it up to a battery charger and at 50amps it turns very slowly and seems to grind and only turns intermittently as some times it doesn't turn at all. So now I'm thinking the brushes are wore out. Going to try to contact a buddy with an alternator shop. Also going to try to find an impact driver to get the cover off because I heard something fall.
Does anyone have any leads for starter parts or a new gasket for the cover. I have a motorcycle junkyard I might try if I can avoid working 70 hours this week. 12-15 hour days don't leave me with much time or energy one the week starts up again. Thanks for helping a kawasaki newbie guys!
Old 10-13-2008   #9 (permalink)
StarGate
StarGate's Avatar
Rob, check the sticky thread in the vintage section of the forum. There is one with a list of parts suppliers for older bikes.
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
Old 10-14-2008   #10 (permalink)
Rob277
Update: I got some new brushes in the starter and it cranks like a champ now. Had a little trouble getting it started as it has been sitting for probably a year or o little over. a shot of starting fluid and she fired up. She runs but a little rough. Seems the carbs may be clogged up. It stutters if you open up the throttle, and when riding tends to rev when i let off the throttle. Choking it tends to make it run a little smoother. Could probably use a valve adjustment too. First step is to bleed out the front brake, then I'll see about a little tune up. So far I'm impressed with the bike
Starter switch problem 900 Custom Azpackrat85 Kawasaki Cruisers 0 06-12-2008 01:40 PM
Starter? Kawa 1982 Vintage Motorcyle Info 7 08-29-2007 10:12 PM
Starter problem txcaptdan Kawasaki Cruisers 2 07-28-2006 08:48 PM
More Electrical Problems, 84 GPz 750 Old GPz Lover The Mechanics Corner 0 07-05-2006 08:43 AM
81 kz-1100 starter problems ggenovez The Mechanics Corner 1 02-15-2006 06:47 PM
