Old 10-14-2008   #1 (permalink)
lightlord
Default 250 wont start
2003 ninja 250 stock... ok fella's im not that great with trouble shooting this stuff now that i am at this point. got the bike from another guy that treated the bike like crap.. unknown amount of time the bike was not running.. after i got it i fixed the timing got it started only to find the head gasket was blown.. replaced the head gasket and plugs.. been aprox 2 months and now it will not start.. will turn over and with a lil eaither try to but no go.. i think the gas might be bad.. smells a bit weird and is a deep amber color.. cleaned carbs and still no go.. both plugs fire.. good compression out the pipes.
lightlord is offline   Reply With Quote
Old 10-14-2008   #2 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
Drain the carbs and gas tank and put new gas in. Pull the plugs and make sure it has a strong blue spark. Orange or weak spark is bad.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 10-14-2008   #3 (permalink)
lightlord
ok did all that and re-gapped the plugs.. sprayed some eather and tried to crank her and she backfired on me but still didnt start.. pulled plug and not wet at all.. i know the carbs are getting fuel but i dont know if the plugs are.. she will only try and fire up when i spray eaither.. so i am thinking one of four things... timing issue, bad plugs, no fuel getting to the cylinders, or last the head is warped and i missed it and she isnt getting the compression she should
Old 10-14-2008   #4 (permalink)
StarGate
StarGate's Avatar
Not drawing fuel into the cyl, backfiring, head has been off, sounds like you might have the cam timing out of sync.
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
Old 10-16-2008   #5 (permalink)
lightlord
retimed the bike still backfireing and not drawing fuel.. when i pulled the carbs the jets are blocked entirely.. got a mechanic and a friend coming to help me out
Old 10-16-2008   #6 (permalink)
StarGate
StarGate's Avatar
I'll ask this just because it happened to another mbr recently. Are you absolutely sure you didn't get the cams swapped and now in the wrong positions?
Mike
Original Owner
1981 KZ1000-K1 LTD
Photos
Old 10-18-2008   #7 (permalink)
lightlord
actually the manual shows to put them in backwards but no i didnt.
KLX 250 Kick Start Problem mastermccance Kawasaki Motocross and Offroad 1 07-14-2008 03:01 PM
Ninja 250 won't start. I think I messed something up (carb sync). balzaK The Mechanics Corner 4 06-02-2008 09:16 PM
Hot Start KX 250 F Picky The Mechanics Corner 0 09-07-2007 08:08 PM
Installed FE, now it won't start..ideas? GOODTIMESROLL Kawasaki Streetbikes/Sportbikes 10 09-07-2007 04:39 PM
klx 250 wont start jayhitman The Mechanics Corner 0 08-25-2007 05:09 PM
