Does the fuel pump get voltage when key is turned on or only after the engine starts? If voltage is there before the engine is started then mine isnt working. Now the question would be, where is the ground or signal coming from that allows the pump to receive power from the relay?
Surely someone will know how this works. Thanks, Russ
LinkBack URL
About LinkBacks
