2000 Vulcan VN800A running rough after oil change
+ Reply to Thread
Results 1 to 17 of 17
Thread: 2000 Vulcan VN800A running rough after oil change
  1. #1
    Newbie mjkearns's Avatar
    Join Date
    Apr 2006
    Location
    Baton Rouge. Louisiana
    Posts
    9
    Default 2000 Vulcan VN800A running rough after oil change
    2000 VN800A, 12.7K miles
    Just changed the oil, and cycle started missing, especially when first hitting the throttle. I pulled the plugs to check wear and gap. They looked pretty good so I regapped and replaced. The bike sat up a lot during our rainy season and don't know if that might have gunked up the carb. It cranks quick, and runs pretty good with the choke out, but once I shut off choke, it misses when I first hit the throttle and I can feel/hear it missing from time to time when I'm revving it. Any inexpensive quick fixes I can try before I have to break it down to get to carbs, etc.?
    mjkearns
    2000 VN800A
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    No Significant Other BTK Expert MFolks's Avatar
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,117
    Go to either Wal-Mart or any good auto parts store and for about $7 buy a can of fuel additive called "Seafoam" Follow the instructions on the can. It will help dissolve any crud in the fuel system.
    Mike Folks
  4. #3
    Keeper of Donkey Forum Supporter jeffs99vulcan's Avatar
    Join Date
    Jun 2008
    Location
    Ottawa, ON
    Posts
    13,880
    +1 on the Seafoam... and +1 on starting with the simple cheap solutions first. The 800's are well known to be reliable, it's something simple and I'm going either bad gas, or gunked up carb.
    Try to get new gas in there as soon as possible, siphon what you have if it's that bad, but stick with 87 octane...
    Good luck, welcome to the forum, and update us as you go!
    Jeff - Ottawa, Ontario
    '99 Vulcan 800 Classic
  5. #4
    I'm NOT the boss BTK Expert Tendofreak's Avatar
    Join Date
    Sep 2008
    Location
    Lakeland, Fl
    Posts
    929
    Does it sit outside in the rain? You mentioned that it "sat-up" for awhile during rainy season. Just courious if it was IN the rain or OUT of the rain. Will make a big difference in the remedy for your problem. But first thing is to drain the old gas, get new gas and an additive in there to burn out any mositure trapped.
    The number one rule of motorcycling ?????
    ARRIVE ALIVE !!!
  6. #5
    Join Date
    Apr 2006
    Location
    Posts
    9
    Tendofreak, it is garage kept.
    mjkearns
    2000 VN800A
  7. #6
    Join Date
    Apr 2006
    Location
    Posts
    9
    OK, I rechecked the gap on the plugs, bought some seafoam and added to the tank. I ran it about 10 miles at what I thought was pretty high rpms. Today I pulled the aircleaner and noticed it smelled heavy of fuel. I ran it without the cleaner and even shot some carb cleaner into the carb. It runs OK with the choke pulled, but as soon as the choke is off, it start sputtering and when I pull the throttle, I can see gas blow out of the carb. Any additional thoughts?
    mjkearns
    2000 VN800A
  8. #7
    Join Date
    Jun 2008
    Location
    Ottawa, ON
    Posts
    13,880
    Can't say for sure what the deal is with the gas blowing through the carb, I'm not a carb guy... but are you sure the sputtering when the choke is pushed in isn't the idle speed adjustment?
  9. #8
    Join Date
    Apr 2006
    Location
    Posts
    9
    It also backfires frequently from the carb.
    mjkearns
    2000 VN800A
  10. #9
    Join Date
    Apr 2006
    Location
    Posts
    9
    By the way, what is the best way to drain the tank? While I added Seafoam, I think I'd rather be sure that if it's bad gas, or water in the tank, that it's cleared out. I want to start with a fresh tank of gas.
    mjkearns
    2000 VN800A
  11. #10
    JUST WANT TO CRUZ BTK Expert cosmicsclassic's Avatar
    Join Date
    Jul 2008
    Location
    Severn,MD
    Posts
    887
    could be bad gas or water. to drain tank, remove fuel line from bottom of petcock, install a temp. peice of hose from petcock to a catch can, turn valve to prime. tank should drain. sounds like water in carb too. to drain , remove air cleaner cover-filter and back plate. watch out for hoses attached to back of plate. once removed, at the bottom of the carb there is a hose nipple, attach a peice of hose to the carb bowl, just above the hose nipple is the bowl drain valve. you will need a 3mm allenhead wrench, turn counter-clockwise and carb should drain. a little work but not hard.
  12. #11
    Patriot Guardian Extreme Forum Supporter RichLockyer's Avatar
    Join Date
    May 2006
    Location
    Chino, CA
    Posts
    28,016
    Ya... sounds like bad gas or water.
    Running well with the choke on and having problems with it off is normally a sign that it is running too lean... probably due to a plugged jet.
    Remove and drain the tank, dump in a pint of acetone and swish it around to take up any water that might remain in the tank (don't get it on the paint!), dump the acetone, and refill with fresh fuel and a half a can of Seafoam.
    Take it for a good run with the Seafoam in the system, then park it for a few days to allow the Seafoam to work on cleaning the carbs.
    If it doesn't gradually improve, then the carbs probably need to be worked on.
    You didn't mention if the idle is high or the engine seems to be racing... a vacuum leak from a cracked carb boot can mimic a lean condition... but you're looking at pulling the carb(s) to replace that. Cleaning the tank and running Seafoam is cheaper and easier, and if it works, you're back on the road in a couple of days.
    - Rich
    2006 1600 Ultra-Classic
    Patriot Guard Rider
  13. #12
    Join Date
    Apr 2006
    Location
    Posts
    9
    OK, thanks to MLK I had the day off. I emptied my tank and drained the carburetor. I got fresh gas and put approximately 1/2 can of seafoam in the tank. I started it up and as I said before, it runs great with the choke, but as soon as I shut it off, the motor bogs and sputters and backfires out of the carb. I noticed that if I impede the airflow into the carb with my fingers, the engine smooths out. I'm guessing this further points to the bike running too lean and possibly a plugged jet? I'm strapped right now, and can't afford to take it in for service, and I'm not a very strong mechanic either. Is it possible that the seafoam will unplug the jet? I'm having to sell it because my truck up and died on me and I need to have something that I can haul my kids around in. Obviously I'll have a better time selling it if it is running good. Thanks to all for the help so far.
    mjkearns
    2000 VN800A
  14. #13
    Join Date
    May 2006
    Location
    Chino, CA
    Posts
    28,016
    Give it a few days for the Seafoam to work.
    Someone recently took their ATV out of storage and Seafoam "fixed" it almost immediately, but it can also take some time if it is badly blocked.
    Another thing that might help if it's still acting up after sitting, is rev the engine to a moderately high RPM, chop the throttle, and immediately block the intake with your hand... anything that's loosened up but still partially blocking the idle jets may be drawn through by the high vacuum.
    - Rich
    Patriot Guard Rider
  15. #14
    Join Date
    Jun 2008
    Location
    Ottawa, ON
    Posts
    13,880
    Can you ride it? Can you take it for a good run and get that half can of Seafoam through it? Don't be shy with it, you won't break anything, but don't get so far away from home that if you have trouble getting it started (which is doesn't sound like is the problem) that you end up walking...
    But the Seafoam has a better chance of doing it's thing but you have to get it through the system...
  16. #15
    Join Date
    May 2006
    Location
    Chino, CA
    Posts
    28,016
    It's "in" the system... he drained the tank and the bowls, so as soon as he started it, it was pulled into the jets.
    - Rich
    Patriot Guard Rider
  17. #16
    Join Date
    Jun 2008
    Location
    Ottawa, ON
    Posts
    13,880
    Quote Originally Posted by RichLockyer View Post
    The stuff's not instant though, is it? I've used it, but only once... won't it have a better chance of cleaning out jets and small orifices if it's flowing, and flowing over a longer time than just a few minutes of idle? With all parts in full range of motion, opening, closing, different flow rates... I dunno, I'm only imagining how it must work, but I'm no Seafoam pro!
  18. #17
    Join Date
    May 2006
    Location
    Chino, CA
    Posts
    28,016
    Quote Originally Posted by jeffs99vulcan View Post
    The idle circuit would be best served by "soaking" with occasional running.
    The needle is pretty much self-cleaning as it moves up and down in the orifice... and the main jet is too big to completely plug unless there's some serious debris in the bowl (which probably would have gotten stuck in the float valve).
    Like I said... soak it a day or two, take it out and run it to high RPM, chopping the throttle, and see if it improves over time.
    If not, then high RPM, chop the throttle, and block the intake to pull hard on the idle circuit... if that doesn't do it, the carb needs to come off and apart for cleaning.
    Multi-carb racks are a pain, but a single carb can be torn down completely, cleaned in parts dip, and reassembled in an hour plus the soaking time.
    - Rich
    Patriot Guard Rider
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 2000 Vulcan running like crap
    By cdz28 in forum The Mechanics Corner
    Last Post: 07-17-2007, 05:47 PM
  2. V2K Oil Change!
    By mele in forum Kawasaki Cruisers
    Last Post: 05-24-2007, 09:47 AM
  3. Replies: 170
    Last Post: 12-12-2006, 05:12 PM
  4. oil change instructions for Vulcan 900
    By cow900 in forum Kawasaki Cruisers
    Last Post: 08-15-2006, 08:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
